Quick start
Get started quickly by following these steps.
![One](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-1.png)
Operating System:
RHEL 7.5 or later and 8.x
OL 7.5 or later and 8.x
SLES 15 SP4
NetApp Cloud Storage:
Amazon FSx for NetApp ONTAP
Cloud Volumes ONTAP
Azure NetApp Files
Storage layouts:
NFS v3 and v4.1 (including dNFS)
iSCSI with ASM (ASMFD, ASMLib and ASMUdev)
Azure NetApp Files does not support SAN environment.
Database layouts: Oracle Standard and Oracle Enterprise Standalone (legacy and multitenant CDB and PDB)
Database versions: 19c and 21c
![Two](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-2.png)
BlueXP is accessible from a web-based console. When you get started with BlueXP, your first step is to sign up using your existing NetApp Support Site credentials or by creating a NetApp cloud login. For information, refer to Sign up to BlueXP.
![Three](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-3.png)
After you sign up to BlueXP, you can log in from the web-based console. For information, refer to Log into BlueXP.
![Four](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-4.png)
You can administer your account by managing users, service accounts, workspaces, and Connectors. For information, refer to Manage your BlueXP account.
