Active IQ Unified Manager 9.8
9.8
Snapshot Copies on a Volume dialog box
You can use the Snapshot Copies on a Volume dialog box to view the list of Snapshot copies. You can delete a Snapshot copy to conserve or free disk space, or if the copy is no longer required. You can also calculate the amount of disk space that can be reclaimed if one or more Snapshot copies are deleted.
List view
The list view displays, in tabular format, information about the Snapshot copies on the volume. You can use the column filters to customize the data that is displayed.
  • Snapshot Copy
    Displays the name of the Snapshot copy.
  • Used Space %
    Displays, in percentage, the total space used by the Snapshot copy in the volume.
  • Total Size
    Displays the total size of the Snapshot copy.
  • Created Time
    Displays the timestamp when the Snapshot copy was created.
  • Dependency
    Displays the applications that are dependent on the Snapshot copy. The possible values are SnapMirror, SnapVault, SnapLock, Dump, LUNs, Vclone, and Busy.
Command buttons
The command buttons enable you to perform the following tasks:
  • Calculate
    Enables you to calculate the space that can be reclaimed by deleting one or more Snapshot copies.
  • Delete Selected
    Deletes one or more Snapshot copies.
  • Close
    Closes the Snapshot Copies on a Volume dialog box.
  • Recalculate
    Enables you to calculate the space that can be reclaimed by deleting the selected Snapshot copies for FlexVol volumes. This button is not available for FlexGroup volumes.
    The Recalculate button is enabled when you make any changes in the selection of the Snapshot copies.
