Setup and administration
Manually install the Connector in Azure
Contributors netapp-bcammett
To manually install the Connector on your own Linux host, you need to review host requirements, set up your networking, prepare Azure permissions, install the Connector, and then provide the permissions that you prepared.
Before you begin
You should review Connector limitations.
Step 1: Review host requirements
The Connector software must run on a host that meets specific operating system requirements, RAM requirements, port requirements, and so on.
Dedicated host
The Connector is not supported on a host that is shared with other applications. The host must be a dedicated host.
Supported operating systems
  • Ubuntu 22.04 LTS
  • CentOS 7.6, 7.7, 7.8, and 7.9
  • Red Hat Enterprise Linux 7.6, 7.7, 7.8, and 7.9
    The host must be registered with Red Hat Subscription Management. If it's not registered, the host can't access repositories to update required 3rd-party software during Connector installation.
    The Connector is supported on English-language versions of these operating systems.
Hypervisor
A bare metal or hosted hypervisor that is certified to run Ubuntu, CentOS, or Red Hat Enterprise Linux is required.
CPU
4 cores or 4 vCPUs
RAM
14 GB
Azure VM size
An instance type that meets the CPU and RAM requirements above. We recommend DS3 v2.
Disk space in /opt
100 GiB of space must be available
Disk space in /var
20 GiB of space must be available
Docker Engine
Docker Engine is required on the host before you install the Connector.
Step 2: Set up networking
Ensure that the network location where you plan to install the Connector supports the following requirements. Meeting these requirements enables the Connector to manage resources and processes within your hybrid cloud environment.
Azure region
If you use Cloud Volumes ONTAP, the Connector should be deployed in the same Azure region as the Cloud Volumes ONTAP systems that it manages, or in the Azure region pair for the Cloud Volumes ONTAP systems. This requirement ensures that an Azure Private Link connection is used between Cloud Volumes ONTAP and its associated storage accounts.
Connections to target networks
A Connector requires a network connection to the location where you're planning to create and manage working environments. For example, the network where you plan to create Cloud Volumes ONTAP systems or a storage system in your on-premises environment.
Outbound internet access
The network location where you deploy the Connector must have an outbound internet connection to contact specific endpoints.
Endpoints contacted during manual installation
When you manually install the Connector on your own Linux host, the installer for the Connector requires access to the following URLs during the installation process:
  • https://support.netapp.com
  • https://mysupport.netapp.com
  • https://cloudmanager.cloud.netapp.com/tenancy
  • https://stream.cloudmanager.cloud.netapp.com
  • https://production-artifacts.cloudmanager.cloud.netapp.com
  • https://*.blob.core.windows.net
  • https://cloudmanagerinfraprod.azurecr.io
    The host might try to update operating system packages during installation. The host can contact different mirroring sites for these OS packages.
Endpoints contacted from the Connector
The Connector requires outbound internet access to contact the following endpoints in order to manage resources and processes within your public cloud environment for day-to-day operations.
Note that the endpoints listed below are all CNAME entries.
Endpoints Purpose
https://management.azure.com
https://login.microsoftonline.com
https://blob.core.windows.net
https://core.windows.net
To manage resources in Azure public regions.
https://management.chinacloudapi.cn
https://login.chinacloudapi.cn
https://blob.core.chinacloudapi.cn
https://core.chinacloudapi.cn
To manage resources in Azure China regions.
To obtain licensing information and to send AutoSupport messages to NetApp support.
https://*.api.bluexp.netapp.com
https://api.bluexp.netapp.com
https://*.cloudmanager.cloud.netapp.com
https://netapp-cloud-account.auth0.com
To provide SaaS features and services within BlueXP.
Note that the Connector is currently contacting "cloudmanager.cloud.netapp.com" but it will start contacting "api.bluexp.netapp.com" in an upcoming release.
To upgrade the Connector and its Docker components.
Proxy server
If your organization requires deployment of a proxy server for all outgoing internet traffic, obtain the following information about your HTTP or HTTPS proxy. You'll need to provide this information during installation.
  • IP address
  • Credentials
  • HTTPS certificate
Note that BlueXP does not support transparent proxy servers.
Ports
There's no incoming traffic to the Connector, unless you initiate it or if the Connector is used as a proxy to send AutoSupport messages from Cloud Volumes ONTAP to NetApp Support.
  • HTTP (80) and HTTPS (443) provide access to the local UI, which you'll use in rare circumstances.
  • SSH (22) is only needed if you need to connect to the host for troubleshooting.
  • Inbound connections over port 3128 are required if you deploy Cloud Volumes ONTAP systems in a subnet where an outbound internet connection isn't available.
    If Cloud Volumes ONTAP systems don't have an outbound internet connection to send AutoSupport messages, BlueXP automatically configures those systems to use a proxy server that's included with the Connector. The only requirement is to ensure that the Connector's security group allows inbound connections over port 3128. You'll need to open this port after you deploy the Connector.
Enable NTP
If you're planning to use BlueXP classification to scan your corporate data sources, you should enable a Network Time Protocol (NTP) service on both the BlueXP Connector system and the BlueXP classification system so that the time is synchronized between the systems. Learn more about BlueXP classification
Step 3: Set up permissions
You need to provide Azure permissions to BlueXP by using one of the following options:
  • Option 1: Assign a custom role to the Azure VM using a system-assigned managed identity.
  • Option 2: Provide BlueXP with the credentials for an Azure service principal that has the required permissions.
Follow the steps to prepare permissions for BlueXP.
Custom role
Note that you can create an Azure custom role using the Azure portal, Azure PowerShell, Azure CLI, or REST API. The following steps show how to create the role using the Azure CLI. If you would prefer to use a different method, refer to Azure documentation
Steps
  1. If you're planning to manually install the software on your own host, enable a system-assigned managed identity on the VM so that you can provide the required Azure permissions through a custom role.
  2. Copy the contents of the custom role permissions for the Connector and save them in a JSON file.
  3. Modify the JSON file by adding Azure subscription IDs to the assignable scope.
    You should add the ID for each Azure subscription that you want to use with BlueXP.
    Example
    "AssignableScopes": [
    "/subscriptions/d333af45-0d07-4154-943d-c25fbzzzzzzz",
    "/subscriptions/54b91999-b3e6-4599-908e-416e0zzzzzzz",
    "/subscriptions/398e471c-3b42-4ae7-9b59-ce5bbzzzzzzz"
  4. Use the JSON file to create a custom role in Azure.
    The following steps describe how to create the role by using Bash in Azure Cloud Shell.
    1. Start Azure Cloud Shell and choose the Bash environment.
    2. Upload the JSON file.
      A screenshot of the Azure Cloud Shell where you can choose the option to upload a file.
    3. Use the Azure CLI to create the custom role:
      az role definition create --role-definition Connector_Policy.json
Result
You should now have a custom role called BlueXP Operator that you can assign to the Connector virtual machine.
Service principal
Create and set up a service principal in Microsoft Entra ID and obtain the Azure credentials that BlueXP needs.
Create a Microsoft Entra application for role-based access control
  1. Ensure that you have permissions in Azure to create an Active Directory application and to assign the application to a role.
  2. From the Azure portal, open the Microsoft Entra ID service.
    Shows the Active Directory service in Microsoft Azure.
  3. In the menu, select App registrations.
  4. Select New registration.
  5. Specify details about the application:
    • Name: Enter a name for the application.
    • Account type: Select an account type (any will work with BlueXP).
    • Redirect URI: You can leave this field blank.
  6. Select Register.
    You've created the AD application and service principal.
Assign the application to a role
  1. Create a custom role:
    1. Copy the contents of the custom role permissions for the Connector and save them in a JSON file.
    2. Modify the JSON file by adding Azure subscription IDs to the assignable scope.
      You should add the ID for each Azure subscription from which users will create Cloud Volumes ONTAP systems.
      Example
    3. Use the JSON file to create a custom role in Azure.
      • Start Azure Cloud Shell and choose the Bash environment.
      • Upload the JSON file.
      • Use the Azure CLI to create the custom role:
  2. Assign the application to the role:
    1. From the Azure portal, open the Subscriptions service.
    2. Select the subscription.
    3. Select Access control (IAM) > Add > Add role assignment.
    4. In the Role tab, select the BlueXP Operator role and select Next.
    5. In the Members tab, complete the following steps:
      • Keep User, group, or service principal selected.
      • Select Select members.
        A screenshot of the Azure portal that shows the Members tab when adding a role to an application.
      • Search for the name of the application.
        Here's an example:
        A screenshot of the Azure portal that shows the Add role assignment form in the Azure portal.
      • Select the application and select Select.
      • Select Next.
    6. Select Review + assign.
      The service principal now has the required Azure permissions to deploy the Connector.
      If you want to deploy Cloud Volumes ONTAP from multiple Azure subscriptions, then you must bind the service principal to each of those subscriptions. BlueXP enables you to select the subscription that you want to use when deploying Cloud Volumes ONTAP.
Add Windows Azure Service Management API permissions
  1. In the Microsoft Entra ID service, select App registrations and select the application.
  2. Select API permissions > Add a permission.
  3. Under Microsoft APIs, select Azure Service Management.
    A screenshot of the Azure portal that shows the Azure Service Management API permissions.
  4. Select Access Azure Service Management as organization users and then select Add permissions.
    A screenshot of the Azure portal that shows adding the Azure Service Management APIs.
Get the application ID and directory ID for the application
  2. Copy the Application (client) ID and the Directory (tenant) ID.
    A screenshot that shows the application (client) ID and directory (tenant) ID for an application in Microsoft Entra IDy.
    When you add the Azure account to BlueXP, you need to provide the application (client) ID and the directory (tenant) ID for the application. BlueXP uses the IDs to programmatically sign in.
Create a client secret
  1. Open the Microsoft Entra ID service.
  2. Select App registrations and select your application.
  3. Select Certificates & secrets > New client secret.
  4. Provide a description of the secret and a duration.
  5. Select Add.
  6. Copy the value of the client secret.
    A screenshot of the Azure portal that shows a client secret for the Microsoft Entra service principal.
    You now have a client secret that BlueXP can use it to authenticate with Microsoft Entra ID.
Result
Your service principal is now setup and you should have copied the application (client) ID, the directory (tenant) ID, and the value of the client secret. You need to enter this information in BlueXP when you add an Azure account.
Step 4: Install the Connector
After the pre-requisites are complete, you can manually install the software on your own Linux host.
Before you begin
You should have the following:
  • Root privileges to install the Connector.
  • Details about a proxy server, if a proxy is required for internet access from the Connector.
    You have the option to configure a proxy server after installation but doing so requires restarting the Connector.
  • A CA-signed certificate, if the proxy server uses HTTPS or if the proxy is an intercepting proxy.
  • A managed identity enabled on the VM in Azure so that you can provide the required Azure permissions through a custom role.
About this task
The installer that is available on the NetApp Support Site might be an earlier version. After installation, the Connector automatically updates itself if a new version is available.
Steps
  1. Verify that docker is enabled and running.
    sudo systemctl enable docker && sudo systemctl start docker
  2. If the http_proxy or https_proxy system variables are set on the host, remove them:
    unset http_proxy
    unset https_proxy
    If you don't remove these system variables, the installation will fail.
  3. Download the Connector software from the NetApp Support Site, and then copy it to the Linux host.
    You should download the "online" Connector installer that's meant for use in your network or in the cloud. A separate "offline" installer is available for the Connector, but it's only supported with private mode deployments.
  4. Assign permissions to run the script.
    chmod +x BlueXP-Connector-Cloud-<version>
    Where <version> is the version of the Connector that you downloaded.
  5. Run the installation script.
     ./BlueXP-Connector-Cloud-<version> --proxy <HTTP or HTTPS proxy server> --cacert <path and file name of a CA-signed certificate>
    The --proxy and --cacert parameters are optional. If you have a proxy server, you will need to enter the parameters as shown. The installer doesn't prompt you to provide information about a proxy.
    Here's an example of the command using both optional parameters:
     ./BlueXP-Connector-Cloud-v3.9.38 --proxy https://user:password@10.0.0.30:8080/ --cacert /tmp/cacert/certificate.cer
    --proxy configures the Connector to use an HTTP or HTTPS proxy server using one of the following formats:
    • http://address:port
    • http://user-name:password@address:port
    • http://domain-name%92user-name:password@address:port
    • https://address:port
    • https://user-name:password@address:port
    • https://domain-name%92user-name:password@address:port
      Note the following:
      • The user can be a local user or domain user.
      • For a domain user, you must use the ASCII code for the \ as shown above.
      • BlueXP doesn't support passwords that include the @ character.
    --cacert specifies a CA-signed certificate to use for HTTPS access between the Connector and the proxy server. This parameter is required only if you specify an HTTPS proxy server or if the proxy is an intercepting proxy.
  6. Wait for the installation to complete.
    At the end of the installation, the Connector service (occm) restarts twice if you specified a proxy server.
  7. Open a web browser from a host that has a connection to the Connector virtual machine and enter the following URL:
    https://ipaddress
  8. After you log in, set up the Connector:
    1. Specify the BlueXP account to associate with the Connector.
    2. Enter a name for the system.
    3. Under Are you running in a secured environment? keep restricted mode disabled.
      You should keep restricted mode disabled because these steps describe how to use BlueXP in standard mode. You should enable restricted mode only if you have a secure environment and want to disconnect this account from BlueXP backend services. If that's the case, follow steps to get started with BlueXP in restricted mode.
    4. Select Let's start.
Result
The Connector is now installed and is set up with your BlueXP account.
If you have Azure Blob storage in the same Azure subscription where you created the Connector, you'll see an Azure Blob storage working environment appear on the BlueXP canvas automatically. Learn how to manage Azure Blob storage from BlueXP
Step 5: Provide permissions to BlueXP
Now that you've installed the Connector, you need to provide BlueXP with the Azure permissions that you previously set up. Providing the permissions enables BlueXP to manage your data and storage infrastructure in Azure.
Custom role
Go to the Azure portal and assign the Azure custom role to the Connector virtual machine for one or more subscriptions.
Steps
  1. From the Azure Portal, open the Subscriptions service and select your subscription.
    It's important to assign the role from the Subscriptions service because this specifies the scope of the role assignment at the subscription level. The scope defines the set of resources that the access applies to. If you specify a scope at a different level (for example, at the virtual machine level), your ability to complete actions from within BlueXP will be affected.
  2. Select Access control (IAM) > Add > Add role assignment.
  3. In the Role tab, select the BlueXP Operator role and select Next.
    Note BlueXP Operator is the default name provided in the BlueXP policy. If you chose a different name for the role, then select that name instead.
  4. In the Members tab, complete the following steps:
    1. Assign access to a Managed identity.
    2. Select Select members, select the subscription in which the Connector virtual machine was created, under Managed identity, choose Virtual machine, and then select the Connector virtual machine.
    3. Select Select.
    4. Select Next.
    5. Select Review + assign.
    6. If you want to manage resources in additional Azure subscriptions, switch to that subscription and then repeat these steps.
Result
BlueXP now has the permissions that it needs to perform actions in Azure on your behalf.
What's next?
Go to the BlueXP console to start using the Connector with BlueXP.
Service principal
Steps
  1. In the upper right of the BlueXP console, select the Settings icon, and select Credentials.
    A screenshot that shows the Settings icon in the upper right of the BlueXP console.
  2. Select Add Credentials and follow the steps in the wizard.
    1. Credentials Location: Select Microsoft Azure > Connector.
    2. Define Credentials: Enter information about the Microsoft Entra service principal that grants the required permissions:
      • Application (client) ID
      • Directory (tenant) ID
      • Client Secret
    3. Marketplace Subscription: Associate a Marketplace subscription with these credentials by subscribing now or by selecting an existing subscription.
    4. Review: Confirm the details about the new credentials and select Add.
Result
