• Provision NAS storage
    • NFS configuration
      • NFS configuration workflow
      • Create a new NFS-enabled SVM
      • Configure NFS access to an existing SVM
      • Add an NFS volume to an NFS-enabled SVM
    • NFS configuration for ESXi using VSC
      • NFS Client Configuration for ESXi workflow
        • Configure the ESXi host
    • SMB/CIFS and NFS multiprotocol configuration
      • Multiprotocol configuration workflow
        • Decide where to provision the new volume
    • SMB/CIFS configuration
      • SMB/CIFS configuration workflow
      • Create a new CIFS-enabled SVM
      • Configure SMB/CIFS access to an existing SVM
      • Add a CIFS volume to a CIFS-enabled SVM
  • Provision SAN storage
    • FC configuration for ESXi using VSC
      • FC configuration workflow
        • Decide where to provision the volume
    • FC configuration for Red Hat Enterprise Linux
      • FC configuration and provisioning workflow
    • FC configuration for Windows
    • iSCSI configuration for ESXi using VSC
      • iSCSI configuration workflow
    • iSCSI configuration for Red Hat Enterprise Linux
      • iSCSI configuration and provisioning workflow
    • iSCSI configuration for Windows
  • Data protection and disaster recovery
    • Cluster and SVM peering configuration
      • Cluster and SVM peering workflow
        • Configure peer relationships (Beginning with ONTAP 9.3)
        • Configure peer relationships (ONTAP 9.2 and earlier)
    • Volume disaster recovery
      • Volume disaster recovery workflow
        • Activate the destination volume
        • Reactivate the source volume
    • Volume disaster recovery preparation
      • Volume disaster recovery preparation workflow
    • Volume backup using SnapVault
      • SnapVault backup configuration workflow
    • Volume restore management using SnapVault
      • Volume restore workflow
  • Cluster administration
      • Cluster expansion administration
        • Cluster expansion workflow
          • Verify the cluster is ready for expansion
          • Prepare the cluster for expansion
          • Install the new nodes
          • Complete the expansion
    • Volume move management
      • Volume move workflow
    • SNMP configuration
      • SNMP configuration workflow
  • Cluster management using System Manager 9.6 and 9.7
      • Set up the cluster by using ONTAP System Manager
        • Set up a cluster by using the template file
      • Set up physical storage
      • Create SVMs
      • Manage clusters
        • MetroCluster switchover and switchback
      • Applications
      • Update clusters
      • Storage tiers
      • Disks
      • SVM Dashboard window
      • Volumes
      • LUNs
      • CIFS protocol
      • Set up NVMe
      • Manage QoS policy groups
      • Local windows group
      • Mirror relationships
      • Vault relationships
      • Mirror and vault relationships
  • Network management for ONTAP 9.7 and earlier
    • NAS path failover workflow (ONTAP 9.7 and earlier)
    • Broadcast domains (ONTAP 9.7 or earlier)
    • General networking topics (ONTAP 9.7 and earlier)
