• Installation
    • What Snap Creator Framework does
      • Snap Creator architecture
    • Preinstallation requirements for Snap Creator
      • Creating a Snap Creator user for Data ONTAP
      • Configuring settings for the Domino plug-in
        • Configuring UNIX-specific settings: Creating symbolic links
    • Installing the Snap Creator Server
      • Installing the Snap Creator Server on a Windows host
    • Installing the Snap Creator Agent
      • Installing Snap Creator Agent on Windows
    • Upgrading Snap Creator
      • Upgrading from Snap Creator 3.6.x
      • Upgrading from Snap Creator 4.0.x
      • Upgrading from Snap Creator 4.1.x
    • Uninstalling Snap Creator
      • Uninstalling Snap Creator on UNIX
    • CLI reference
      • CLI commands for creating a role for a Snap Creator user in clustered Data ONTAP
  • IBM Domino Plug-in Operations
    • IBM Domino plug-in overview
    • Preparing for IBM Domino backup and restore
      • SnapMirror and SnapVault setup
    • Creating a backup and restore configuration
      • Adding commands to the backup and restore configuration
    • Backing up databases
    • Restoring databases
      • Performing a single-file restore in a SAN environment
    • Viewing job status and logs
  • SAP HANA Plug-in Operations
    • SAP HANA backup and restore solution overview
    • Installing and configuring required software components
    • Configuring data backups
      • Starting the SnapVault relationships
    • Configuring log backups
    • Executing database backups
    • SAP HANA File-Based Backup and Database Integrity Checks
    • Restoring and recovering SAP HANA databases
      • Resuming a SnapVault relationship after a restore
      • Restoring databases after primary storage failure
  • Administration
    • Managing Snap Creator Server
    • Managing Snap Creator Agent
      • Snap Creator Agent security
    • Backup and recovery workflow
      • Creating retention policies
      • Creating clones
      • Performing restore operations
    • Managing user access
    • Managing profiles
    • Managing configuration files
    • Managing retention policies
    • Managing backups
    • Managing scheduled jobs
    • Managing clones
    • Plug-in information required to configure Snap Creator
      • VMware VIBE plug-in
    • Troubleshooting Snap Creator issues
      • Types of error messages and troubleshooting logs
      • Troubleshooting Snap Creator GUI errors
      • Troubleshooting security issues
      • Troubleshooting Snap Creator Server or Snap Creator Agent issues
      • Troubleshooting CLI command errors
      • Error messages
    • Snap Creator configuration file variables, parameters, and commands
    • Guidelines for using the Snap Creator command-line interface
