Configuration requirements for NVIDIA SN2100 switches
- PDF of this doc site
Creating your file...
For NVIDIA SN2100 switch installation and maintenance, be sure to review all configuration requirements.
Installation requirements
If you want to build ONTAP clusters with more than two nodes, you need two supported cluster network switches. You can use additional management switches, which are optional.
You install the NVIDIA SN2100 switch (X190006) in the NVIDIA dual/single switch cabinet with the standard brackets that are included with the switch.
For cabling guidelines, see Review cabling and configuration considerations.
ONTAP and Linux support
The NVIDIA SN2100 switch is a 10/25/40/100GbE switch running Cumulus Linux. The switch supports the following:
ONTAP 9.10.1P3.
The SN2100 switch serves Cluster and Storage applications in ONTAP 9.10.1P3 over different switch-pairs.
Cumulus Linux (CL) OS version.
In order to download the SN2100 Cumulus software from NVIDIA, you must have login credentials to access NVIDIA's Enterprise Support Portal. See the Knowledge Base article How to register with NVIDIA for Enterprise Support Portal Access. For current compatibility information, see the NVIDIA Ethernet Switches information page.
You can install Cumulus Linux when the switch is running Cumulus Linux or ONIE.
