Cluster and storage switches
Documentation requirements for BES-53248 cluster switches
Contributors netapp-jolieg
For BES-53248 switch installation and maintenance, be sure to review the specific switch and controller documentation.
Broadcom documentation
To set up the BES-53248 cluster switch, you need the following documents available from the Broadcom Support Site: Broadcom Ethernet Switch Product Line
Document title Description
EFOS Administrator's Guide v3.4.3
Provides examples of how to use the BES-53248 switch in a typical network.
EFOS CLI Command Reference v3.4.3
Describes the command-line interface (CLI) commands you use to view and configure the BES-53248 software.
EFOS Getting Started Guide v3.4.3
Provides detailed information about for the BES-53248 switch.
EFOS SNMP Reference Guide v3.4.3
EFOS Scaling Parameters and Values v3.4.3
Describes the default scaling parameters with which EFOS software is delivered and validated on the supported platforms.
EFOS Functional Specifications v3.4.3
Describes the specifications for the EFOS software on the supported platforms.
EFOS Release Notes v3.4.3
Provides release-specific information about BES-53248 software.
Cluster Network and Management Network Compatibility Matrix
Provides information on network compatibility. The matrix is available from the BES-53248 switch download site at Broadcom cluster switches.
ONTAP systems documentation and KB articles
To set up an ONTAP system, you need the following documents from the NetApp Support Site at mysupport.netapp.com or the Knowledgebase (KB) site at kb.netapp.com.
Name Description
Describes the power and site requirements for all NetApp hardware, including system cabinets, and provides information on the relevant connectors and cable options to use along with their part numbers.
Controller-specific Installation and Setup Instructions
Describes how to install NetApp hardware.
ONTAP 9
Provides detailed information about all aspects of the ONTAP 9 release.
How to add additional port licensing for the Broadcom-supported BES-53248 switch
Provides detailed information on adding port licenses. Go to the KB article.
