Upgrade Cumulus Linux versions
Complete the following procedure to upgrade your Cumulus Linux version as required.
Intermediate-level Linux knowledge.
Familiarity with basic text editing, UNIX file permissions, and process monitoring. A variety of text editors are pre-installed, including
vi
andnano
Access to a Linux or UNIX shell. If you are running Windows, use a Linux environment as your command line tool for interacting with Cumulus Linux.
The baud rate requirement is set to 115200 on the serial console switch for NVIDIA SN2100 switch console access, as follows:
115200 baud
8 data bits
1 stop bit
parity: none
flow control: none
Be aware of the following:
Each time Cumulus Linux is upgraded, the entire file system structure is erased and rebuilt. Your existing configuration will be erased. You must save and record your switch configuration before updating Cumulus Linux. |
The default password for the cumulus user account is cumulus. The first time you log into Cumulus Linux, you must change this default password. You must update any automation scripts before installing a new image. Cumulus Linux provides command line options to change the default password automatically during the installation process. |
Check the current Cumulus Linux version and connected ports:
admin@sw1:mgmt:~$ net show system Hostname......... cumulus Build............ Cumulus Linux 4.4.3 Uptime........... 0:08:20.860000 Model............ Mlnx X86 CPU.............. x86_64 Intel Atom C2558 2.40GHz Memory........... 8GB Disk............. 14.7GB ASIC............. Mellanox Spectrum MT52132 Ports............ 16 x 100G-QSFP28 Part Number...... MSN2100-CB2FC Serial Number.... MT2105T05177 Platform Name.... x86_64-mlnx_x86-r0 Product Name..... MSN2100 ONIE Version..... 2019.11-5.2.0020-115200 Base MAC Address. 04:3F:72:43:92:80 Manufacturer..... Mellanox admin@sw1:mgmt:~$ net show interface State Name Spd MTU Mode LLDP Summary ----- ------ ---- ----- ---------- ---------------------- -------------------- . . UP swp1 100G 9216 Trunk/L2 node1 (e5b) Master: bridge(UP) UP swp2 100G 9216 Trunk/L2 node2 (e5b) Master: bridge(UP) UP swp3 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp4 100G 9216 Trunk/L2 SHFFG1826000112 (e0b) Master: bridge(UP) UP swp5 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP) UP swp6 100G 9216 Trunk/L2 SHFFG1826000102 (e0b) Master: bridge(UP)) . .
Download the Cumulux Linux 5.x image:
admin@sw1:mgmt:~$ sudo onie-install -a -i http://10.60.132.97/x/eng/testbedN,svl/nic/files/NVIDIA/cumulus-linux-5.4.0-mlx-amd64.bin/ [sudo] password for cumulus: Fetching installer: http://10.60.132.97/x/eng/testbedN,svl/nic/files/NVIDIA/cumulus-linux-5.4.0-mlx-amd64.bin Downloading URL: http://10.60.132.97/x/eng/testbedN,svl/nic/files/NVIDIA/cumulus-linux-5.4.0-mlx-amd64.bin # 100.0% Success: HTTP download complete. EFI variables are not supported on this system Warning: SecureBoot is not available. Image is signed. . . . Staging installer image...done. WARNING: WARNING: Activating staged installer requested. WARNING: This action will wipe out all system data. WARNING: Make sure to back up your data. WARNING: Are you sure (y/N)? y Activating staged installer...done. Reboot required to take effect.
Reboot the switch:
admin@sw1:mgmt:~$ sudo onie-install -a -i http://10.60.132.97/x/eng/testbedN,svl/nic/files/NVIDIA/cumulus-linux-5.4.0-mlx-amd64.bin/ sudo reboot
Change the password:
cumulus login: cumulus Password: You are required to change your password immediately (administrator enforced) Changing password for cumulus. Current password: cumulus New password: <new_password> Retype new password: <new_password> Linux cumulus 5.10.0-cl-1-amd64 #1 SMP Debian 5.10.162-1+cl5.4.0u1 (2023-01-20) x86_64 Welcome to NVIDIA Cumulus (R) Linux (R) ZTP in progress. To disable, do 'ztp -d'
Check the Cumulus Linux version:
nv show system
cumulus@cumulus:mgmt:~$ nv show system operational applied ---------- -------------- ---------- hostname cumulus cumulus build Cumulus Linux 5.4.0 uptime 14:07:08 timezone Etc/UTC
Change the hostname:
cumulus@cumulus:mgmt:~$ nv set system hostname sw1 cumulus@cumulus:mgmt:~$ nv config apply Warning: The following files have been changed since the last save, and they WILL be overwritten. - /etc/nsswitch.conf - /etc/synced/synced.conf . .
Logout and log in to the switch again to see the updated switch name at the prompt:
cumulus@cumulus:mgmt:~$ exit logout Debian GNU/Linux 10 cumulus ttyS0 cumulus login: cumulus Password: Last login: Tue Dec 15 21:43:13 UTC 2020 on ttyS0 Linux cumulus 5.10.0-cl-1-amd64 #1 SMP Debian 5.10.162-1+cl5.4.0u1 (2023-01-20) x86_64 Welcome to NVIDIA Cumulus (R) Linux (R) ZTP in progress. To disable, do 'ztp -d' cumulus@sw1:mgmt:~$
Set the IP address:
cumulus@sw1:mgmt:~$ nv set interface eth0 ip address 10.231.80.206 cumulus@sw1:mgmt:~$ nv set interface eth0 ip gateway 10.231.80.1 cumulus@sw1:mgmt:~$ nv config apply applied [rev_id: 2] cumulus@sw1:mgmt:~$ ip route show vrf mgmt default via 10.231.80.1 dev eth0 proto kernel unreachable default metric 4278198272 10.231.80.0/22 dev eth0 proto kernel scope link src 10.231.80.206 127.0.0.0/8 dev mgmt proto kernel scope link src 127.0.0.1
Create a new user and add this user to the
sudo
group. This user only becomes effective after the console/SSH session is restarted.sudo adduser --ingroup netedit admin
cumulus@sw1:mgmt:~$ sudo adduser --ingroup netedit admin [sudo] password for cumulus: Adding user 'admin' ... Adding new user 'admin' (1001) with group `netedit' ... Creating home directory '/home/admin' ... Copying files from '/etc/skel' ... New password: Retype new password: passwd: password updated successfully Changing the user information for admin Enter the new value, or press ENTER for the default Full Name []: Room Number []: Work Phone []: Home Phone []: Other []: Is the information correct? [Y/n] y cumulus@sw1:mgmt:~$ sudo adduser admin sudo [sudo] password for cumulus: Adding user `admin' to group `sudo' ... Adding user admin to group sudo Done. cumulus@sw1:mgmt:~$ exit logout Connection to 10.233.204.71 closed. [admin@cycrh6svl01 ~]$ ssh admin@10.233.204.71 admin@10.233.204.71's password: Linux sw1 4.19.0-cl-1-amd64 #1 SMP Cumulus 4.19.206-1+cl4.4.1u1 (2021-09-09) x86_64 Welcome to NVIDIA Cumulus (R) Linux (R) For support and online technical documentation, visit http://www.cumulusnetworks.com/support The registered trademark Linux (R) is used pursuant to a sublicense from LMI, the exclusive licensee of Linus Torvalds, owner of the mark on a world-wide basis. admin@sw1:mgmt:~$
Add additional user groups for the admin user to access
nv
commands:cumulus@sw1:mgmt:~$ sudo adduser admin nvshow [sudo] password for cumulus: Adding user `admin' to group `nvshow' ... Adding user admin to group nvshow Done.
See NVIDIA User Accounts for more information.
admin@sw1:mgmt:~$ nv show system operational applied ------------------- -------------------- ----------------- hostname cumulus cumulus build Cumulus Linux 5.3.0 uptime 6 days, 8:37:36 timezone Etc/UTC admin@sw1:mgmt:~$ nv show interface Interface MTU Speed State Remote Host Remote Port- Type Summary ------------- ----- ----- ----- ------------------- ------------ --------- ------------- + cluster_isl 9216 200G up bond + eth0 1500 100M up mgmt-sw1 Eth105/1/14 eth IP Address: 10.231.80 206/22 eth0 IP Address: fd20:8b1e:f6ff:fe31:4a0e/64 + lo 65536 up loopback IP Address: 127.0.0.1/8 lo IP Address: ::1/128 + swp1s0 9216 10G up cluster01 e0b swp . . . + swp15 9216 100G up sw2 swp15 swp + swp16 9216 100G up sw2 swp16 swp
Download the Cumulux Linux 5.4.0 image:
Reboot the switch:
admin@sw1:mgmt:~$ sudo reboot
nv show system
cumulus@cumulus:mgmt:~$ nv show system operational applied -------------- ---------------- hostname cumulus cumulus build Cumulus Linux 5.4.0 uptime 14:07:08 timezone Etc/UTC
Logout and log in again to the switch to see the updated switch name at the prompt:
Set the IP address:
sudo
nv
