Install the Reference Configuration File (RCF)
Follow this procedure to install the RCF after setting up the Nexus 3132Q-V switch for the first time. You can also use this procedure to upgrade your RCF version.
Review requirements
A current backup of the switch configuration.
A fully functioning cluster (no errors in the logs or similar issues).
The current Reference Configuration File (RCF).
A console connection to the switch, required when installing the RCF.
Cisco Ethernet switch. Consult the switch compatibility table for the supported ONTAP and RCF versions. Note that there can be command dependencies between the command syntax in the RCF and that found in versions of NX-OS.
Cisco Nexus 3000 Series Switches. Consult the appropriate software and upgrade guides available on the Cisco web site for complete documentation on the Cisco switch upgrade and downgrade procedures.
Install the file
The examples in this procedure use the following switch and node nomenclature:
The names of the two Cisco switches are
cs1
andcs2
The node names are
cluster1-01
,cluster1-02
,cluster1-03
, andcluster1-04
The cluster LIF names are
cluster1-01_clus1
,cluster1-01_clus2
,cluster1-02_clus1
,cluster1-02_clus2
,cluster1-03_clus1
,cluster1-03_clus2
,cluster1-04_clus1
, andcluster1-04_clus2
The
cluster1::*>
prompt indicates the name of the cluster.
The procedure requires the use of both ONTAP commands and Cisco Nexus 3000 Series Switches commands; ONTAP commands are used unless otherwise indicated.
No operational inter-switch link (ISL) is needed during this procedure. This is by design because RCF version changes can affect ISL connectivity temporarily. To ensure non-disruptive cluster operations, the following procedure migrates all of the cluster LIFs to the operational partner switch while performing the steps on the target switch.
Be sure to complete the procedure in Prepare to install NX-OS software and Reference Configuration File, and then follow the steps below.
Step 1: Check port status
Display the cluster ports on each node that are connected to the cluster switches:
network device-discovery show
Show example
cluster1::*> network device-discovery show Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ---------------- ------------ cluster1-01/cdp e0a cs1 Ethernet1/7 N3K-C3132Q-V e0d cs2 Ethernet1/7 N3K-C3132Q-V cluster1-02/cdp e0a cs1 Ethernet1/8 N3K-C3132Q-V e0d cs2 Ethernet1/8 N3K-C3132Q-V cluster1-03/cdp e0a cs1 Ethernet1/1/1 N3K-C3132Q-V e0b cs2 Ethernet1/1/1 N3K-C3132Q-V cluster1-04/cdp e0a cs1 Ethernet1/1/2 N3K-C3132Q-V e0b cs2 Ethernet1/1/2 N3K-C3132Q-V cluster1::*>
Check the administrative and operational status of each cluster port.
Verify that all the cluster ports are up with a healthy status:
network port show -ipspace Cluster
Show example
cluster1::*> network port show -ipspace Cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false 8 entries were displayed. Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false cluster1::*>
Verify that all the cluster interfaces (LIFs) are on the home port:
network interface show -vserver Cluster
Show example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ----------------- ------------ ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*>
Verify that the cluster displays information for both cluster switches:
system cluster-switch show -is-monitoring-enabled-operational true
Show example
cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- --------------- cs1 cluster-network 10.0.0.1 NX3132QV Serial Number: FOXXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP cs2 cluster-network 10.0.0.2 NX3132QV Serial Number: FOXXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP 2 entries were displayed.
For ONTAP 9.8 and later, use the command system switch ethernet show -is-monitoring-enabled-operational true
Disable auto-revert on the cluster LIFs.
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert false
Make sure that auto-revert is disabled after running this command.
On cluster switch cs2, shut down the ports connected to the cluster ports of the nodes.
cs2(config)# interface eth1/1/1-2,eth1/7-8 cs2(config-if-range)# shutdown
Verify that the cluster ports have migrated to the ports hosted on cluster switch cs1. This might take a few seconds.
Show example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ----------------- ---------- ------------------ ------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0a true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0a false cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0a true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0a false cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0a true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0a false cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0a true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0a false cluster1::*>
Verify that the cluster is healthy:
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------ ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false cluster1::*>
Step 2: Configure and verify the setup
If you have not already done so, save a copy of the current switch configuration by copying the output of the following command to a text file:
show running-config
Clean the configuration on switch cs2 and perform a basic setup.
When updating or applying a new RCF, you must erase the switch settings and perform basic configuration. You must be connected to the switch serial console port to set up the switch again. -
Clean the configuration:
Show example
(cs2)# write erase Warning: This command will erase the startup-configuration. Do you wish to proceed anyway? (y/n) [n] y
Perform a reboot of the switch:
Show example
(cs2)# reload Are you sure you would like to reset the system? (y/n) y
Copy the RCF to the bootflash of switch cs2 using one of the following transfer protocols: FTP, TFTP, SFTP, or SCP. For more information on Cisco commands, see the appropriate guide in the Cisco Nexus 3000 Series NX-OS Command Reference guides.
Show example
cs2# copy tftp: bootflash: vrf management Enter source filename: Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt Enter hostname for the tftp server: 172.22.201.50 Trying to connect to tftp server......Connection to Server Established. TFTP get operation was successful Copy complete, now saving to disk (please wait)...
Apply the RCF previously downloaded to the bootflash.
Show example
cs2# copy Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands
Examine the banner output from the
show banner motd
command. You must read and follow the instructions under Important Notes to ensure the proper configuration and operation of the switch.Show example
cs2# show banner motd ****************************************************************************** * NetApp Reference Configuration File (RCF) * * Switch : Cisco Nexus 3132Q-V * Filename : Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt * Date : Nov-02-2020 * Version : v1.6 * * Port Usage : Breakout configuration * Ports 1- 6: Breakout mode (4x10GbE) Intra-Cluster Ports, int e1/1/1-4, * e1/2/1-4, e1/3/1-4,int e1/4/1-4, e1/5/1-4, e1/6/1-4 * Ports 7-30: 40GbE Intra-Cluster/HA Ports, int e1/7-30 * Ports 31-32: Intra-Cluster ISL Ports, int e1/31-32 * * IMPORTANT NOTES * - Load Nexus_3132QV_RCF_v1.6-Cluster-HA.txt for non breakout config * * - This RCF utilizes QoS and requires specific TCAM configuration, requiring * cluster switch to be rebooted before the cluster becomes operational. * * - Perform the following steps to ensure proper RCF installation: * * (1) Apply RCF, expect following messages: * - Please save config and reload the system... * - Edge port type (portfast) should only be enabled on ports... * - TCAM region is not configured for feature QoS class IPv4... * * (2) Save running-configuration and reboot Cluster Switch * * (3) After reboot, apply same RCF second time and expect following messages: * - % Invalid command at '^' marker * * (4) Save running-configuration again * * - If running NX-OS versions 9.3(5) 9.3(6), 9.3(7), or 9.3(8) * - Downgrade the NX-OS firmware to version 9.3(5) or earlier if * NX-OS using a version later than 9.3(5). * - Do not upgrade NX-OS prior to applying v1.9 RCF file. * - After the RCF is applied and switch rebooted, then proceed to upgrade * NX-OS to version 9.3(5) or later. * * - If running 9.3(9) 10.2(2) or later the RCF can be applied to the switch * after the upgrade. * * - Port 1 multiplexed H/W configuration options: * hardware profile front portmode qsfp (40G H/W port 1/1 is active - default) * hardware profile front portmode sfp-plus (10G H/W ports 1/1/1 - 1/1/4 are active) * hardware profile front portmode qsfp (To reset to QSFP) * ******************************************************************************
Verify that the RCF file is the correct newer version:
show running-config
When you check the output to verify you have the correct RCF, make sure that the following information is correct:
The RCF banner
The node and port settings
Customizations
The output varies according to your site configuration. Check the port settings and refer to the release notes for any changes specific to the RCF that you have installed.
For steps on how to bring your 10GbE ports online after an upgrade of the RCF, see the Knowledge Base article 10GbE ports on a Cisco 3132Q cluster switch do not come online.
After you verify the RCF versions and switch settings are correct, copy the running-config file to the startup-config file.
Show example
cs2# copy running-config startup-config [########################################] 100% Copy complete
Reboot switch cs2. You can ignore the "cluster ports down" events reported on the nodes while the switch reboots.
Show example
cs2# reload This command will reboot the system. (y/n)? [n] y
Apply the same RCF and save the running configuration for a second time.
Show example
cs2# copy Nexus_3132QV_RCF_v1.6-Cluster-HA-Breakout.txt running-config echo-commands cs2# copy running-config startup-config [########################################] 100% Copy complete
Verify the health of cluster ports on the cluster.
Verify that cluster ports are up and healthy across all nodes in the cluster:
Show example
cluster1::*> network port show -ipspace Cluster Node: cluster1-01 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-02 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/10000 healthy false e0b Cluster Cluster up 9000 auto/10000 healthy false Node: cluster1-03 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false Node: cluster1-04 Ignore Speed(Mbps) Health Health Port IPspace Broadcast Domain Link MTU Admin/Oper Status Status --------- ------------ ---------------- ---- ---- ----------- -------- ------ e0a Cluster Cluster up 9000 auto/100000 healthy false e0d Cluster Cluster up 9000 auto/100000 healthy false
Verify the switch health from the cluster.
network device-discovery show -protocol cdp
Show example
cluster1::*> network device-discovery show -protocol cdp Node/ Local Discovered Protocol Port Device (LLDP: ChassisID) Interface Platform ----------- ------ ------------------------- ----------------- -------- cluster1-01/cdp e0a cs1 Ethernet1/7 N3K-C3132Q-V e0d cs2 Ethernet1/7 N3K-C3132Q-V cluster01-2/cdp e0a cs1 Ethernet1/8 N3K-C3132Q-V e0d cs2 Ethernet1/8 N3K-C3132Q-V cluster01-3/cdp e0a cs1 Ethernet1/1/1 N3K-C3132Q-V e0b cs2 Ethernet1/1/1 N3K-C3132Q-V cluster1-04/cdp e0a cs1 Ethernet1/1/2 N3K-C3132Q-V e0b cs2 Ethernet1/1/2 N3K-C3132Q-V cluster1::*> system cluster-switch show -is-monitoring-enabled-operational true Switch Type Address Model --------------------------- ------------------ ---------------- ----- cs1 cluster-network 10.233.205.90 N3K-C3132Q-V Serial Number: FOXXXXXXXGD Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP cs2 cluster-network 10.233.205.91 N3K-C3132Q-V Serial Number: FOXXXXXXXGS Is Monitored: true Reason: None Software Version: Cisco Nexus Operating System (NX-OS) Software, Version 9.3(4) Version Source: CDP 2 entries were displayed.
.You might observe the following output on the cs1 switch console depending on the RCF version previously loaded on the switch:
2020 Nov 17 16:07:18 cs1 %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port port-channel1 on VLAN0092. Port consistency restored. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_PEER: Blocking port-channel1 on VLAN0001. Inconsistent peer vlan. 2020 Nov 17 16:07:23 cs1 %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking port-channel1 on VLAN0092. Inconsistent local vlan.
It can take up to 5 minutes for the cluster nodes to report as healthy.
On cluster switch cs1, shut down the ports connected to the cluster ports of the nodes.
Show example
cs1(config)# interface eth1/1/1-2,eth1/7-8 cs1(config-if-range)# shutdown
Verify that the cluster LIFs have migrated to the ports hosted on switch cs2. This might take a few seconds.
Show example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d false cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d false cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b false cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b false cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*>
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- -------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false 4 entries were displayed. cluster1::*>
Repeat Steps 1 to 10 on switch cs1.
Enable auto-revert on the cluster LIFs.
Show example
cluster1::*> network interface modify -vserver Cluster -lif * -auto-revert True
Reboot switch cs1. You do this to trigger the cluster LIFs to revert to their home ports. You can ignore the "cluster ports down" events reported on the nodes while the switch reboots.
cs1# reload This command will reboot the system. (y/n)? [n] y
Step 3: Verify the configuration
Verify that the switch ports connected to the cluster ports are up.
show interface brief | grep up
Show example
cs1# show interface brief | grep up . . Eth1/1/1 1 eth access up none 10G(D) -- Eth1/1/2 1 eth access up none 10G(D) -- Eth1/7 1 eth trunk up none 100G(D) -- Eth1/8 1 eth trunk up none 100G(D) -- . .
Verify that the ISL between cs1 and cs2 is functional:
show port-channel summary
Show example
cs1# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed b - BFD Session Wait S - Switched R - Routed U - Up (port-channel) p - Up in delay-lacp mode (member) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 1 Po1(SU) Eth LACP Eth1/31(P) Eth1/32(P) cs1#
Verify that the cluster LIFs have reverted to their home port:
Show example
cluster1::*> network interface show -vserver Cluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ------------------ ---------- ------------------ ------------------- ------- ---- Cluster cluster1-01_clus1 up/up 169.254.3.4/23 cluster1-01 e0d true cluster1-01_clus2 up/up 169.254.3.5/23 cluster1-01 e0d true cluster1-02_clus1 up/up 169.254.3.8/23 cluster1-02 e0d true cluster1-02_clus2 up/up 169.254.3.9/23 cluster1-02 e0d true cluster1-03_clus1 up/up 169.254.1.3/23 cluster1-03 e0b true cluster1-03_clus2 up/up 169.254.1.1/23 cluster1-03 e0b true cluster1-04_clus1 up/up 169.254.1.6/23 cluster1-04 e0b true cluster1-04_clus2 up/up 169.254.1.7/23 cluster1-04 e0b true cluster1::*>
cluster show
Show example
cluster1::*> cluster show Node Health Eligibility Epsilon -------------------- ------- ------------- ------- cluster1-01 true true false cluster1-02 true true false cluster1-03 true true true cluster1-04 true true false cluster1::*>
Ping the remote cluster interfaces to verify connectivity:
cluster ping-cluster -node local
Show example
cluster1::*> cluster ping-cluster -node local Host is cluster1-03 Getting addresses from network interface table... Cluster cluster1-03_clus1 169.254.1.3 cluster1-03 e0a Cluster cluster1-03_clus2 169.254.1.1 cluster1-03 e0b Cluster cluster1-04_clus1 169.254.1.6 cluster1-04 e0a Cluster cluster1-04_clus2 169.254.1.7 cluster1-04 e0b Cluster cluster1-01_clus1 169.254.3.4 cluster1-01 e0a Cluster cluster1-01_clus2 169.254.3.5 cluster1-01 e0d Cluster cluster1-02_clus1 169.254.3.8 cluster1-02 e0a Cluster cluster1-02_clus2 169.254.3.9 cluster1-02 e0d Local = 169.254.1.3 169.254.1.1 Remote = 169.254.1.6 169.254.1.7 169.254.3.4 169.254.3.5 169.254.3.8 169.254.3.9 Cluster Vserver Id = 4294967293 Ping status: ............ Basic connectivity succeeds on 12 path(s) Basic connectivity fails on 0 path(s) ................................................ Detected 9000 byte MTU on 12 path(s): Local 169.254.1.3 to Remote 169.254.1.6 Local 169.254.1.3 to Remote 169.254.1.7 Local 169.254.1.3 to Remote 169.254.3.4 Local 169.254.1.3 to Remote 169.254.3.5 Local 169.254.1.3 to Remote 169.254.3.8 Local 169.254.1.3 to Remote 169.254.3.9 Local 169.254.1.1 to Remote 169.254.1.6 Local 169.254.1.1 to Remote 169.254.1.7 Local 169.254.1.1 to Remote 169.254.3.4 Local 169.254.1.1 to Remote 169.254.3.5 Local 169.254.1.1 to Remote 169.254.3.8 Local 169.254.1.1 to Remote 169.254.3.9 Larger than PMTU communication succeeds on 12 path(s) RPC status: 6 paths up, 0 paths down (tcp check) 6 paths up, 0 paths down (udp check)
For ONTAP 9.8 and later, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files by using the commands:
system switch ethernet log setup-password
andsystem switch ethernet log enable-collection
Enter:
Show example
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system switch ethernet log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password>
Enter:
Show example
cluster1::*> system switch ethernet log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
If any of these commands return an error, contact NetApp support. -
For ONTAP releases 9.5P16, 9.6P12, and 9.7P10 and later patch releases, enable the Ethernet switch health monitor log collection feature for collecting switch-related log files by using the commands:
system cluster-switch log setup-password
andsystem cluster-switch log enable-collection
Enter:
Show example
cluster1::*> system cluster-switch log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system cluster-switch log setup-password Enter the switch name: cs1 RSA key fingerprint is e5:8b:c6:dc:e2:18:18:09:36:63:d9:63:dd:03:d9:cc Do you want to continue? {y|n}::[n] y Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system cluster-switch log setup-password Enter the switch name: cs2 RSA key fingerprint is 57:49:86:a1:b9:80:6a:61:9a:86:8e:3c:e3:b7:1f:b1 Do you want to continue? {y|n}:: [n] y Enter the password: <enter switch password> Enter the password again: <enter switch password>
Enter:
Show example
cluster1::*> system cluster-switch log enable-collection Do you want to enable cluster log collection for all nodes in the cluster? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*>
