Ethernet Switch Health Monitoring log collection
The Ethernet switch health monitor (CSHM) is responsible for ensuring the operational health of Cluster and Storage network switches and collecting switch logs for debugging purposes. This procedure guides you through the process of setting up and starting the collection of detailed Support logs from the switch and starts an hourly collection of Periodic data that is collected by AutoSupport.
The user for log collection must be specified when the Reference Configuration File (RCF) is applied. By default, this user is set to 'admin'. If you wish to use a different user, you must specify this in the *# SHM User*s section of the RCF.
The user must have access to the nv show commands. This can be added by running
sudo adduser USER nv show
and replacing USER with the user for log collection. -
Switch health monitoring must be enabled for the switch. Verify this by ensuring the
Is Monitored:
field is set to true in the output of thesystem switch ethernet show
command.
To set up log collection, run the following command for each switch. You are prompted to enter the switch name, username, and password for log collection.
system switch ethernet log setup-password
Show example
cluster1::*> system switch ethernet log setup-password Enter the switch name: <return> The switch name entered is not recognized. Choose from the following list: cs1 cs2 cluster1::*> system switch ethernet log setup-password Enter the switch name: cs1 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password> cluster1::*> system switch ethernet log setup-password Enter the switch name: cs2 Would you like to specify a user other than admin for log collection? {y|n}: n Enter the password: <enter switch password> Enter the password again: <enter switch password>
To start log collection, run the following command, replacing DEVICE with the switch used in the previous command. This starts both types of log collection: the detailed
Support
logs and an hourly collection ofPeriodic
data.system switch ethernet log modify -device <switch-name> -log-request true
Show example
cluster1::*> system switch ethernet log modify -device cs1 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection. cluster1::*> system switch ethernet log modify -device cs2 -log-request true Do you want to modify the cluster switch log collection configuration? {y|n}: [n] y Enabling cluster switch log collection.
Wait for 10 minutes and then check that the log collection completes:
system switch ethernet log show
If any of these commands return an error or if the log collection does not complete, contact NetApp support.
If you encounter any of the following error statuses reported by the log collection feature (visible in the output of system switch ethernet log show
), try the corresponding debug steps:
Log collection error status |
Resolution |
RSA keys not present |
Regenerate ONTAP SSH keys. Contact NetApp support. |
switch password error |
Verify credentials, test SSH connectivity, and regenerate ONTAP SSH keys. Review switch documentation or contact NetApp support for instructions. |
ECDSA keys not present for FIPS |
If FIPS mode is enabled, ECDSA keys need to be generated on the switch before retrying. |
pre-existing log found |
Remove the previous log collection directory and '.tar' file located at |
switch dump log error |
Ensure the switch user has log collection permissions. Refer to the prerequisites above. |
