• Release Notes
  • What is OnCommand Insight?
  • Installation for Linux
    • Installation prerequisites
      • Planning the deployment
    • Insight installation instructions
      • Installing a Remote Acquisition Unit
      • Checking the installation
        • Installing your Insight licenses
      • Troubleshooting installations
    • Upgrading Insight
    • Uninstalling OnCommand Insight
  • Installation for Microsoft Windows
      • Installing OnCommand Insight Data Warehouse and Reporting
      • Installing a Remote Acquisition Unit (RAU)
    • Upgrading OnCommand Insight
      • Overview of the OnCommand Insight upgrade process
      • Backing up the databases
      • Performing the software upgrade
        • Upgrading Data Warehouse
      • Completing post-upgrade tasks
    • Uninstalling the software
  • Configuration and administration
    • Setting up Insight
      • Setting up and managing user accounts
        • Configuring Insight for LDAP(s)
      • Insight Security (SecurityAdmin Tool)
        • Changing OnCommand Insight internal user passwords
      • Smart Card and certificate login support
      • Setting up weekly backups for your Insight database
      • Performance data archiving
      • Configuring your email
      • Enabling the syslog facility
      • Configuring your ASUP processing
      • Defining applications
      • Your business entities hierarchy
      • Defining annotations
        • Using annotations to monitor your environment
          • Managing annotation types
          • Creating custom annotations
          • Assigning annotations to assets using annotation rules
      • Querying assets
      • Managing performance policies
        • Performance policy evaluation precedence
    • Insight Security
    • Querying assets
    • Insight data source management
      • Setting up your data sources in Insight
        • Adding data sources
      • Vendor-specific data source reference
        • HDS HiCommand Device Manager data source
        • NetApp Clustered Data ONTAP data source
        • NetApp E-Series data source
      • What data source patches are
    • Device resolution
      • Creating device resolution rules
      • Fibre Channel device resolution
      • IP device resolution
    • Maintaining Insight
      • Updating expired licenses
      • Preparing a special troubleshooting report
      • Advanced troubleshooting
        • Moving MySQL data using the migrate option
        • Adding a missing disk model
          • Locating required information for new disk model
    • Monitoring your environment
      • Asset page data
        • Searching your environment for specific assets
        • Asset page sections
          • Summary
          • Topology
          • User Data
          • Expert view
          • Related Assets
          • Violations
          • Customizable asset page
      • Examining network performance
  • Data Warehouse administration
    • Welcome to OnCommand Insight Data Warehouse
      • Data Warehouse components
      • How historical data is retained in Data Warehouse
    • Getting started with Data Warehouse
      • Managing Data Warehouse and Reporting user accounts
      • Data Warehouse database build from history overview
      • Setting up multiple tenancy in reporting
      • Troubleshooting setup issues
        • Why I cannot see my annotations
    • Administrative tasks you can perform using Data Warehouse
      • What you can do using annotations
      • Advanced options
        • Troubleshooting Data Warehouse
          • Issue resolution with ASUP
          • Multiple server chassis consolidation issues
  • Reporting
    • Welcome to OnCommand Insight reporting
    • Reporting made easy
    • Managing reports
    • Creating custom ad hoc reports
      • Process of creating reports
    • Reporting data model
      • Data model overview
  • FAQ
  • How-To guides
    • Getting Started with Insight
      • Setting up notifications
      • Preparing assets: Annotating
      • Finding assets: Querying
      • Your corporate structure: setting up business entities and applications
    • Creating custom dashboards
      • Custom Dashboard concepts
        • Dashboard variables
        • Grouping in table widgets
        • Expressions in dashboard widgets
      • Example storage node utilization dashboard with variables
      • Best Practices for Dashboards and Widgets
    • Creating performance policies
    • Troubleshooting Fibre Channel BB credit 0 errors
    • Analyzing your infrastructure
    • Introduction to minimizing risk in thin provisioning
    • Collecting Host and VM file system utilization data
    • Configuring your system to report chargeback data
      • Assigning applications to assets
    • Ensuring IO density reports describe only internal data volumes
    • Collecting integration data
      • Collecting SNMP Integration data
    • Analyzing an application performance problem
    • Collecting and reporting AWS billing data
      • Reporting on Cloud Cost data in Insight
