Reorder Annotation Rule dialog box
PDF of this doc site
- Online Help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
You can use the Reorder Annotation Rule dialog box to specify the order in which you want annotation rules to be applied to storage objects.
Command buttons
You must have the Application Administrator or Storage Administrator role.
Save
Saves the changes you made to the annotation rules and closes the Reorder Annotation Rule dialog box.
Cancel
Closes the Reorder Annotation Rule dialog box without saving the changes you made.
List View
Rank
Displays the order in which the annotation rules will be applied to the storage objects.
Name
Displays the name of the annotation rule.
Target Object Type
Displays the type of storage object to which the annotation rule is applied.
Associated Annotation
Displays the name of the annotation that is applied to the storage object.
Associated Annotation Value
Displays the annotation value for the storage object.
