BlueXP ransomware protection
Known limitations of BlueXP ransomware protection
Contributors amgrissino
Known limitations identify platforms, devices, or functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
Readiness drill Reset option issue
If you select an ONTAP 9.11.1 volume for the ransomware attack readiness drill, BlueXP ransomware protection notifies you with an alert. If you recovery the data using the "clone-to-volume" option and reset the drill, the reset operation fails.
Amazon FSx for NetApp ONTAP limitations
The Amazon FSx for NetApp ONTAP working environment is supported in BlueXP ransomware protection. The following limitations apply to this working environment:
  • Backup policies are not supported for Fsx for ONTAP. In this environment, you should perform backup operations using the Amazon FS for ONTAP backup service. You can restore these workloads using BlueXP ransomware protection snapshots.
  • Restore operations are performed from snapshots only.
