Download reports in NetApp Ransomware Resilience
You can export protection data and download the CSV or JSON files that show details of attack readiness drills, protection, alerts, and recovery.
Before you download the files, refresh the dashboard to capture the most recent data in your reports. |
Required Console role
To perform this task, you need the Organization admin, Folder or project admin, Ransomware Resilience admin, or Ransomware Resilience viewer role. Learn about Ransomware Resilience roles for NetApp Console.
What data can you download?
You can download files from any of the main menu options:
Summary: Includes lists of supported and unsupported workloads, recommended actions to improve your cyber resiliency posture, and information captured in the Ransomware Resilience dashboard.
Protection: Includes the status and details of all workloads, including the total number protected and at risk.
Alerts: Includes the status and details of all alerts, including the total number of alerts and automated snapshots.
Recovery: Includes the status and details of all workloads that need to be restored, including the total number of workloads marked "Restore needed", "In progress," "Restore failed" and "Successfully restored."
Reports: You can export data from any of the pages and download the files.
You can download readiness drill reports only from the Reports page.
If you download CSV or JSON files from the Protection, Alerts, or Recovery page, the data shows only the data on that page.
The CSV or JSON files include data for all workloads on all Console systems.
From the Console left navigation, select Protection > Ransomware Resilience.
From the Dashboard or other page, select the Refresh
option in the upper right to refresh the data that will appear in the reports. -
Do one of the following:
From the page, select the Download
option. -
From the NetApp Ransomware Resilience menu, select Reports.
If you selected the Reports option, select one of the preconfigured file names and select Download.
