Back up resources using PowerShell cmdlets
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Creating your file...
Backing up a resource includes establishing a connection with the SnapCenter Server, adding resources, adding a policy, creating a backup resource group, and backing up.
You must have prepared the PowerShell environment to execute the PowerShell cmdlets.
You must have added the storage system connection and created a credential.
The information regarding the parameters that can be used with the cmdlet and their descriptions can be obtained by running Get-Help command_name. Alternatively, you can also refer to the SnapCenter Software Cmdlet Reference Guide.
Initiate a connection session with the SnapCenter Server for a specified user by using the Open-SmConnection cmdlet.
Open-smconnection -SMSbaseurl https:\\snapctr.demo.netapp.com:8146\
The username and password prompt is displayed.
Add resources by using the Add-SmResources cmdlet.
This example adds resources:
Add-SmResource -HostName '10.232.206.248' -PluginCode 'DB2' -ResourceName NONREC1 -ResourceType Database -StorageFootPrint ( @ {"VolumeName"="DB2_NONREC1DB";"LunName"="DB2_NONREC1DB";"Vserver"="vserver_scauto_secondary"}) -Instance db2inst1
Create a backup policy by using the Add-SmPolicy cmdlet.
This example creates a new backup policy:
Add-SMPolicy -PolicyName 'db2VolumePolicy' -PolicyType 'Backup' -PluginPolicyType DB2 -description 'VolumePolicy'
Add a new resource group to SnapCenter by using the Add-SmResourceGroup cmdlet.
This example creates a new resource group with the specified policy and resources:
Add-SmResourceGroup -ResourceGroupName 'Verify_ManualBackup_DatabaseLevel_MultipleVolume_unix' -Resources @(@ {"Host"="10.232.206.248";"Uid"="db2inst2\NONREC"},@{"Host"="10.232.206.248";"Uid"="db2inst1\NONREC"}) -Policies db2ManualPolicy
Initiate a new backup job by using the New-SmBackup cmdlet.
New-SMBackup -DatasetName Verify_ManualBackup_DatabaseLevel_MultipleVolume_unix -Policy db2ManualPolicy
View the status of the backup job by using the Get-SmBackupReport cmdlet.
This example displays a job summary report of all jobs that were run on the specified date:
PS C:\> Get-SmBackupReport -JobId 351 Output: BackedUpObjects : {DB1} FailedObjects : {} IsScheduled : False HasMetadata : False SmBackupId : 269 SmJobId : 2361 StartDateTime : 10/4/2016 11:20:45 PM EndDateTime : 10/4/2016 11:21:32 PM Duration : 00:00:46.2536470 CreatedDateTime : 10/4/2016 11:21:09 PM Status : Completed ProtectionGroupName : Verify_ASUP_Message_windows SmProtectionGroupId : 211 PolicyName : test2 SmPolicyId : 20 BackupName : Verify_ASUP_Message_windows_scc54_10-04-2016_23.20.46.2758 VerificationStatus : NotVerified VerificationStatuses : SmJobError : BackupType : SCC_BACKUP CatalogingStatus : NotApplicable CatalogingStatuses : ReportDataCreatedDateTime :
