Storage types supported by Plug-in for Oracle Database
SnapCenter supports a wide range of storage types on both physical and virtual machines. You must verify the support for your storage type before installing the SnapCenter Plug-ins Package for Linux or SnapCenter Plug-ins Package for AIX.
SnapCenter does not support storage provisioning for Linux and AIX.
Storage types supported on Linux
The following table lists the storage types supported on Linux.
Machine | Storage type |
Physical server |
VMware ESXi |
Storage types supported on AIX
The following table lists the storage types supported on AIX.
Machine | Storage type | ||
Physical server |
The NetApp Interoperability Matrix Tool contains the latest information about the supported versions.
