Deployment validation report for partners
NetApp partners can run a deployment validation to verify that a FlexPod converged infrastructure is configured correctly. Partners can then hand off the report to customers.
Log in to the Converged Systems Advisor portal.
Expand the customer's configuration from the Customer List.
Under Deployment Validation Report, click Generate.
Choose whether you want to view the report in your browser, in a PDF, or via email.
Review the report and correct any interoperability issues and deployment validation errors.
Example
In this sample configuration, the firmware versions of the Nexus switches are not supported:
Four validation rules also failed due to issues with switch connectivity:
Upgrading the firmware can correct the interoperability of the configuration and adding the links can correct the failed validation rules.
After you correct the issues, collect data to ensure that Converged Systems Advisor has the latest configuration data:
Select the converged infrastructure.
In the upper right, click Collect.
Generate the report again to verify that you have corrected the issues.
Send the final Deployment Validation Report to your customer.
The converged infrastructure is now set up according to best practices.
