How resources, resource groups, and policies are used for protecting Oracle databases
PDF of this doc site
Protect Microsoft SQL Server databases
Protect SAP HANA databases
Creating your file...
Before you use SnapCenter, it is helpful to understand basic concepts related to the backup, clone, and restore operations you want to perform.
Resources are typically Oracle databases in SnapCenter.
A SnapCenterresource group is a collection of resources on a host or cluster.
When you perform an operation on a resource group, you perform that operation on the resources defined in the resource group.
The resource groups were formerly known as datasets.
The policies specify the backup frequency, copy retention, replication, scripts, and other characteristics of data protection operations.
When you create a resource group, you select one or more policies for that group. You can also select a policy when you perform a backup on demand for a single resource. You can also perform scheduled backups for single resources and resource groups.
Think of a resource group as defining what you want to protect and when you want to protect it in terms of day and time. Think of a policy as defining how you want to protect it.
If you are backing up all databases of a host, for example, you might create a resource group that includes all of the databases in the host. You could then attach two policies to the resource group: a daily policy and an hourly policy. When you create the resource group and attach the policies, you might configure the resource group to perform a full backup daily and another schedule that performs log backups hourly.
The following image illustrates the relationship between resources, resource groups, and policies for databases:
![sco resourcegroup policy](../media/sco_resourcegroup_policy.gif)
