Perform Clone Lifecycle
Using SnapCenter, you can create clones from a resource group or database. You can either perform on-demand clone or you can schedule recurring clone operations of a resource group or database. If you clone a backup periodically, you can use the clone to develop applications, populate data, or recover data.
SnapCenter enables you to schedule multiple clone operations to run simultaneously across multiple servers.
While cloning to a standalone database instance, ensure that the mount point path exists and it is a dedicated disk.
While cloning to a Failover Cluster Instance (FCI), ensure that the mount points exists, it is a shared disk, and the path and the FCI should belong to the same SQL resource group.
If the source database or the target instance is on a cluster shared volume (csv), then the cloned database will be on the csv.
For virtual environments (VMDK/RDM), ensure that the mount point is a dedicated disk. |
The SCRIPTS_PATH is defined using the PredefinedWindowsScriptsDirectory key located in the SMCoreServiceHost.exe.Config file of the plug-in host.
If needed, you can change this path and restart SMcore service. It is recommended that you use the default path for security.
The value of the key can be displayed from swagger through the API: API /4.7/configsettings
You can use the GET API to display the value of the key. SET API is not supported.
Most of the fields on the Clone lifecycle wizard pages are self-explanatory. The following information describes fields for which you might need guidance.
For ONTAP 9.12.1 and below version, if you specify a Snapshot locking period, the clones created from the tamper proof Snapshots will inherit the SnapLock expiry time. Storage admin should manually cleanup the clones post the SnapLock expiry time.
In the left navigation pane, click Resources, and then select the appropriate plug-in from the list.
In the Resources page, select either Database or Resource Group from the View list.
Select the resource group or database, and then click Clone Lifecycle.
In the Options page, perform the following actions:
For this field… Do this… Clone job name
Specify the clone life cycle job name that helps in monitoring and modifying the clone life cycle job.
Clone server
Choose the host on which the clone should be placed.
Clone instance
Choose the clone instance to which you want to clone the database. This SQL instance must be located in the specified clone server.
Clone suffix
Enter a suffix that will be appended to the clone database to identify that it is a clone. Each SQL instance that is used to create a clone resource group must have a unique database name. For example, if the clone resource group contains a source database “db1” from an SQL instance “inst1”, and if “db1” is cloned to “inst1”, then the clone database name should be “db1clone”. “clone” is a mandatory user-defined suffix because the database is cloned to the same instance. If “db1” is cloned to the SQL instance “inst2”, then the clone database name can remain “db1” (the suffix is optional) because the database is cloned to a different instance.
Auto assign mount point or Auto assign volume mount point under path
Choose whether to automatically assign a mount point or volume mount point under a path. Choosing to auto assign a volume mount point under a path enables you to provide a specific directory. The mount points will be created within that directory. Before you choose this option, you must ensure that the directory is empty. If there is a database in the directory, the database will be in an invalid state after the mount operation.
In the Location page, select a storage location to create a clone.
In the Script page, enter the path and the arguments of the prescript or postscript that should be run before or after the clone operation, respectively.
For example, you can run a script to update SNMP traps, automate alerts, send logs, and so on.
The prescripts or postscripts path should not include drives or shares. The path should be relative to the SCRIPTS_PATH. The default script timeout is 60 seconds.
In the Schedule page, perform one of the following actions:
Select Run now if you want to execute the clone job immediately.
Select Configure schedule when you want to determine how frequently the clone operation should occur, when the clone schedule should start, on which day the clone operation should occur, when the schedule should expire, and whether the clones have to be deleted after the schedule expires.
In the Notification page, from the Email preference drop-down list, select the scenarios in which you want to send the emails.
You must also specify the sender and receiver email addresses, and the subject of the email. If you want to attach the report of the clone operation performed, select Attach Job Report.
For email notification, you must have specified the SMTP server details using the either the GUI or the PowerShell command Set-SmSmtpServer. For EMS, you can refer to Manage EMS data collection
Review the summary, and then click Finish.
You should monitor the cloning process using the Monitor > Jobs page.
