Upgrade a management node
You can upgrade your management node to management node version 12.3.x from version 11.0 or later.
Upgrading the management node operating system is no longer required to upgrade Element software on the storage cluster. If the management node is version 11.3 or later, you can simply upgrade the management services to the latest version to perform Element upgrades using NetApp Hybrid Cloud Control. Follow the management node upgrade procedure for your scenario if you would like to upgrade the management node operating system for other reasons, such as security remediation.
The vCenter Plug-in 4.4 or later requires a management node 11.3 or later that is created with modular architecture and provides individual services. |
Choose one of the following management node upgrade options:
If you are upgrading from management node 12.3:
There are no additional functionality changes or bug fixes in management node 12.3.1. If you are already running management node 12.3, you do not need to upgrade it to 12.3.1.
If you choose to proceed with an upgrade on a management node 12.3 deployed using NDE, the upgrade to 12.3.x will complete. However, the upgrade might encounter an error during restart. If this occurs, reboot the management node so that it correctly shows 12.3.x. |
If you are upgrading from management node 12.2:
Upgrade a management node to version 12.3.x from 12.2 -
If you are upgrading from management node 12.0:
Upgrade a management node to version 12.3.x from 12.0 -
If you are upgrading from management node 11.3, 11.5, 11.7, or 11.8:
Upgrade a management node to version 12.3.x from 11.3 through 11.8 -
If you are upgrading from management node 11.0 or 11.1:
Upgrade a management node to version 12.3.x from 11.1 or 11.0 -
If you are upgrading from a management node version 10.x:
Migrating from management node version 10.x to 11.x
Choose the following option if you have sequentially updated (1) your management services version and (2) your Element storage version and you want to keep your existing management node:
If you do not sequentially update your management services followed by Element storage, you cannot reconfigure reauthentication using this procedure. Follow the appropriate upgrade procedure instead. |
If you are keeping existing management node:
Reconfigure authentication using the management node REST API
You can perform an in-place upgrade of the management node from version 12.2 to version 12.3.x without needing to provision a new management node virtual machine.
The Element 12.3.x management node is an optional upgrade. It is not required for existing deployments. |
The RAM of the management node VM is 24GB.
The management node you are intending to upgrade is version 12.0 and uses IPv4 networking. The management node version 12.3.x does not support IPv6.
To check the version of your management node, log in to your management node and view the Element version number in the login banner. -
You have updated your management services bundle to the latest version using NetApp Hybrid Cloud Control (HCC). You can access HCC from the following IP:
https://<ManagementNodeIP> -
If you are updating your management node to version 12.3.x, you need management services 2.14.60 or later to proceed.
You have configured an additional network adapter (if required) using the instructions for configuring an additional storage NIC.
Persistent volumes might require an additional network adapter if eth0 is not able to be routed to the SVIP. Configure a new network adapter on the iSCSI storage network to allow the configuration of persistent volumes. -
Storage nodes are running Element 11.3 or later.
Log in to the management node virtual machine using SSH or console access.
Download the management node ISO for NetApp HCI from the NetApp Support Site to the management node virtual machine.
The name of the ISO is similar to solidfire-fdva-<Element release>-patchX-XX.X.X.XXXX.iso -
Check the integrity of the download by running md5sum on the downloaded file and compare the output to what is available on NetApp Support Site for NetApp HCI or Element software, as in the following example:
sudo md5sum -b <path to iso>/solidfire-fdva-<Element release>-patchX-XX.X.X.XXXX.iso -
Mount the management node ISO image and copy the contents to the file system using the following commands:
sudo mkdir -p /upgrade
sudo mount <solidfire-fdva-<Element release>-patchX-XX.X.X.XXXX.iso> /mnt
sudo cp -r /mnt/* /upgrade
Change to the home directory, and unmount the ISO file from
/mnt:sudo umount /mnt
Delete the ISO to conserve space on the management node:
sudo rm <path to iso>/solidfire-fdva-<Element release>-patchX-XX.X.X.XXXX.iso
On the management node that you are upgrading, run the following command to upgrade your management node OS version. The script retains all necessary configuration files after the upgrade, such as Active IQ collector and proxy settings.
sudo /sf/rtfi/bin/sfrtfi_inplace file:///upgrade/casper/filesystem.squashfs sf_upgrade=1
The management node reboots with a new OS after the upgrade process completes.
After you run the sudo command described in this step, the SSH session is killed. Console access is required for continued monitoring. If no console access is available to you when performing the upgrade, retry the SSH login and verify connectivity after 15 to 30 minutes. Once you log in, you can confirm the new OS version in the SSH banner that indicates that the upgrade was successful. -
On the management node, run the
redeploy-mnodescript to retain previous management services configuration settings:The script retains previous management services configuration, including configuration from the Active IQ collector service, controllers (vCenters), or proxy, depending on your settings. sudo /sf/packages/mnode/redeploy-mnode -mu <mnode user>
If you had previously disabled SSH functionality on the management node, you need to disable SSH again on the recovered management node. SSH capability that provides NetApp Support remote support tunnel (RST) session access is enabled on the management node by default. |
You can perform an in-place upgrade of the management node from version 12.0 to version 12.3.x without needing to provision a new management node virtual machine.
Configure the management node VM RAM:
Power off the management node VM.
Change the RAM of the management node VM from 12GB to 24GB RAM.
Power on the management node VM.
SSH capability that provides NetApp Support remote support tunnel (RST) session access is disabled by default on management nodes running management services 2.18 and later. If you had previously enabled SSH functionality on the management node, you might need to disable SSH again on the upgraded management node. |
You can perform an in-place upgrade of the management node from version 11.3, 11.5, 11.7, or 11.8 to version 12.3.x without needing to provision a new management node virtual machine.
The management node you are intending to upgrade is version 11.3, 11.5, 11.7, or 11.8 and uses IPv4 networking. The management node version 12.3.x does not support IPv6.
On the 11.3, 11.5, 11.7, or 11.8 management node, run the following command to upgrade your management node OS version. The script retains all necessary configuration files after the upgrade, such as Active IQ collector and proxy settings.
You can perform an in-place upgrade of the management node from 11.0 or 11.1 to version 12.3.x without needing to provision a new management node virtual machine.
Use the latest HealthTools to upgrade Element software. -
The management node you are intending to upgrade is version 11.0 or 11.1 and uses IPv4 networking. The management node version 12.3.x does not support IPv6.
For management node 11.0, the VM memory needs to be manually increased to 12GB.
You have configured an additional network adapter (if required) using the instructions for configuring a storage NIC (eth1) in the management node user guide your product.
sudo mount solidfire-fdva-<Element release>-patchX-XX.X.X.XXXX.iso /mnt
Change to the home directory, and unmount the ISO file from /mnt:
sudo umount /mnt
Run one of the following scripts with options to upgrade your management node OS version. Only run the script that is appropriate for your version. Each script retains all necessary configuration files after the upgrade, such as Active IQ collector and proxy settings.
On an 11.1 (11.1.0.73) management node, run the following command:
sudo /sf/rtfi/bin/sfrtfi_inplace file:///upgrade/casper/filesystem.squashfs sf_upgrade=1 sf_keep_paths="/sf/packages/solidfire-sioc-4.2.3.2288 /sf/packages/solidfire-nma-1.4.10/conf /sf/packages/sioc /sf/packages/nma"
On an 11.1 (11.1.0.72) management node, run the following command:
sudo /sf/rtfi/bin/sfrtfi_inplace file:///upgrade/casper/filesystem.squashfs sf_upgrade=1 sf_keep_paths="/sf/packages/solidfire-sioc-4.2.1.2281 /sf/packages/solidfire-nma-1.4.10/conf /sf/packages/sioc /sf/packages/nma"
On an 11.0 (11.0.0.781) management node, run the following command:
sudo /sf/rtfi/bin/sfrtfi_inplace file:///upgrade/casper/filesystem.squashfs sf_upgrade=1 sf_keep_paths="/sf/packages/solidfire-sioc-4.2.0.2253 /sf/packages/solidfire-nma-1.4.8/conf /sf/packages/sioc /sf/packages/nma"
On the 12.3.x management node, run the
upgrade-mnodescript to retain previous configuration settings.If you are migrating from an 11.0 or 11.1 management node, the script copies the Active IQ collector to the new configuration format. -
For a single storage cluster managed by an existing management node 11.0 or 11.1 with persistent volumes:
sudo /sf/packages/mnode/upgrade-mnode -mu <mnode user> -pv <true - persistent volume> -pva <persistent volume account name - storage volume account>
For a single storage cluster managed by an existing management node 11.0 or 11.1 with no persistent volumes:
For multiple storage clusters managed by an existing management node 11.0 or 11.1 with persistent volumes:
sudo /sf/packages/mnode/upgrade-mnode -mu <mnode user> -pv <true - persistent volume> -pva <persistent volume account name - storage volume account> -pvm <persistent volumes mvip>
For multiple storage clusters managed by an existing management node 11.0 or 11.1 with no persistent volumes (the
-pvmflag is to provide one of the cluster's MVIP addresses):sudo /sf/packages/mnode/upgrade-mnode -mu <mnode user> -pvm <mvip for persistent volumes>
(For all NetApp HCI installations with NetApp Element Plug-in for vCenter Server) Update the vCenter Plug-in on the 12.3.x management node by following the steps in the Upgrade the Element Plug-in for vCenter Server topic.
Locate the asset ID for your installation using the management node API:
From a browser, log into the management node REST API UI:
Go to the storage MVIP and log in.
This action causes certificate to be accepted for the next step.
Open the inventory service REST API UI on the management node:
https://<ManagementNodeIP>/inventory/1/
Select Authorize and complete the following:
Enter the cluster user name and password.
Enter the client ID as
mnode-client. -
Select Authorize to begin a session.
Close the window.
From the REST API UI, select GET /installations.
Select Try it out.
Select Execute.
From the code 200 response body, copy the
idfor the installation.Your installation has a base asset configuration that was created during installation or upgrade.
Locate the hardware tag for your compute node in vSphere:
Select the host in the vSphere Web Client navigator.
Select the Monitor tab, and select Hardware Health.
The node BIOS manufacturer and model number are listed. Copy and save the value for
tagfor use in a later step.
Add a vCenter controller asset for HCI monitoring and Hybrid Cloud Control to the management node known assets:
Select POST /assets/{asset_id}/controllers to add a controller sub-asset.
Select Try it out.
Enter the parent base asset ID you copied to your clipboard in the asset_id field.
Enter the required payload values with type
vCenterand vCenter credentials. -
Select Execute.
Add a compute node asset to the management node known assets:
Select POST /assets/{asset_id}/compute-nodes to add a compute node sub-asset with credentials for the compute node asset.
Select Try it out.
In the payload, enter the required payload values as defined in the Model tab. Enter
ESXi Hostastypeand paste the hardware tag you saved during a previous step forhardware_tag. -
Select Execute.
If you have a management node at version 10.x, you cannot upgrade from 10.x to 11.x. You can instead use this migration procedure to copy over the configuration from 10.x to a newly deployed 11.1 management node. If your management node is currently at 11.0 or higher, you should skip this procedure. You need management node 11.0 or 11.1 and the latest HealthTools to upgrade Element software from 10.3 + through 11.x.
From the VMware vSphere interface, deploy the management node 11.1 OVA and power it on.
Open the management node VM console, which brings up the terminal user interface (TUI).
Use the TUI to create a new administrator ID and assign a password.
In the management node TUI, log in to the management node with the new ID and password and validate that it works.
From the vCenter or management node TUI, get the management node 11.1 IP address and browse to the IP address on port 9443 to open the management node UI.
https://<mNode 11.1 IP address>:9443
In vSphere, select NetApp Element Configuration > mNode Settings. (In older versions, the top-level menu is NetApp SolidFire Configuration.)
Select Actions > Clear.
To confirm, select Yes. The mNode Status field should report Not Configured.
When you go to the mNode Settings tab for the first time, the mNode Status field might display as Not Configured instead of the expected UP; you might not be able to choose Actions > Clear. Refresh the browser. The mNode Status field will eventually display UP. -
Log out of vSphere.
In a web browser, open the management node registration utility and select QoSSIOC Service Management:
Set the new QoSSIOC password.
The default password is solidfire. This password is required to set the new password. -
Select the vCenter Plug-in Registration tab.
Select Update Plug-in.
Enter required values. When you are finished, select UPDATE.
Log in to vSphere and select NetApp Element Configuration > mNode Settings.
Select Actions > Configure.
Provide the management node IP address, management node user ID (the user name is
admin), password that you set on the QoSSIOC Service Management tab of the registration utility, and vCenter user ID and password.In vSphere, the mNode Settings tab should display the mNode status as UP, which indicates management node 11.1 is registered to vCenter.
From the management node registration utility (
https://<mNode 11.1 IP address>:9443), restart the SIOC service from QoSSIOC Service Management. -
Wait for one minute and check the NetApp Element Configuration > mNode Settings tab. This should display the mNode status as UP.
If the status is DOWN, check the permissions for
/sf/packages/sioc/app.properties. The file should have read, write, and execute permissions for the file owner. The correct permissions should appear as follows:-rwx------
After the SIOC process starts and vCenter displays mNode status as UP, check the logs for the
sf-hci-nmaservice on the management node. There should be no error messages. -
(For management node 11.1 only) SSH into the management node version 11.1 with root privileges and start the NMA service with the following commands:
# systemctl enable /sf/packages/nma/systemd/sf-hci-nma.service
# systemctl start sf-hci-nma21
Perform actions from vCenter to remove a drive, add a drive or reboot nodes. This triggers storage alerts, which should be reported in vCenter. If this is working, NMA system alerts are functioning as expected.
If ONTAP Select is configured in vCenter, configure ONTAP Select alerts in NMA by copying the
.ots.propertiesfile from the previous management node to the management node version 11.1/sf/packages/nma/conf/.ots.propertiesfile, and restart the NMA service using the following command:systemctl restart sf-hci-nma
Verify that ONTAP Select is working by viewing the logs with the following command:
journalctl -f | grep -i ots
Configure Active IQ by doing the following:
SSH in to the management node version 11.1 and go to the
/sf/packages/collectordirectory. -
Run the following command:
sudo ./manage-collector.py --set-username netapp --set-password --set-mvip <MVIP>
Enter the management node UI password when prompted.
Run the following commands:
./manage-collector.py --get-all
sudo systemctl restart sfcollector
Verify
sfcollectorlogs to confirm it is working.
In vSphere, the NetApp Element Configuration > mNode Settings tab should display the mNode status as UP.
Verify NMA is reporting system alerts and ONTAP Select alerts.
If everything is working as expected, shut down and delete management node 10.x VM.
You can keep your existing management node if you have sequentially upgraded (1) management services and (2) Element storage. If you have followed a different upgrade order, see the procedures for in-place management node upgrades.
You have updated your management services to 2.10.29 or later.
Your storage cluster is running Element 12.0 or later.
Your management node is 11.3 or later.
You have sequentially updated your management services followed by upgrading your Element storage. You cannot reconfigure authentication using this procedure unless you have completed upgrades in the sequence described.
Open the management node REST API UI on the management node:
https://<ManagementNodeIP>/mnode
mnode-clientif the value is not already populated. -
From the REST API UI, select POST /services/reconfigure-auth.
Select Try it out.
For the load_images parameter, select
true. -
Select Execute.
The response body indicates that reconfiguration was successful.
