Deploy a self-managed instance of Astra Control
If you want a self-managed instance of Astra Control that resides inside your network, you can deploy Astra Control Center directly from Astra Control Service.
Steps
In the Getting Started area of the Dashboard, select Deploy a self-managed instance of Astra Control.
Do one of the following:
Generate a new API token by selecting Generate.
Paste in an existing Astra Control REST API token. Refer to the Astra Automation documentation for guidance on generating an API token.
Follow the instructions in the Deploy Astra Control Center window.
