O comando smsap profile check
Você pode executar o comando verificar perfil para verificar a configuração do perfil. Você deve montar o banco de dados antes de executar este comando.
Sintaxe
smsap profile verify -profile profile_name [-quiet | -verbose]
Parâmetros
-profileEspecifica o perfil a ser verificado. O perfil contém o identificador da base de dados e outras informações da base de dados.
-quietExibe apenas mensagens de erro no console. O padrão é exibir mensagens de erro e aviso.
-verboseExibe mensagens de erro, aviso e informativas no console.
Exemplo
O exemplo a seguir verifica o perfil:
smsap profile verify -profile profileA –verbose
[ INFO] SMSAP-13505: SnapDrive environment verification passed.
[ INFO] SMSAP-13507: JDBC verification for "OS authenticated: CER/hostA.rtp.com" passed.
[ INFO] SMSAP-13506: SQLPlus verification for database SID "CER" passed. Environment: [ORACLE_HOME=/u02/app/oracle/product/11.2.0.2]
[ INFO] SMSAP-07431: Saving starting state of the database: CER(OPEN).
[ INFO] SD-00016: Discovering storage resources for /vol/hostA_sap_datavol_CER.
[ INFO] SD-00017: Finished storage discovery for /vol/ hostA_sap_datavol_CER.
[ INFO] SD-00016: Discovering storage resources for /vol/hostA_sap_cntrlvol_CER.
[ INFO] SD-00017: Finished storage discovery for /vol/hostA_sap_cntrlvol_CER.
[ INFO] SD-00016: Discovering storage resources for /vol/hostA_sap_redovol_CER.
[ INFO] SD-00017: Finished storage discovery for /vol/hostA_sap_redovol_CER.
[ INFO] SD-00016: Discovering storage resources for /vol/hostA_sap_archivevol_CER.
[ INFO] SD-00017: Finished storage discovery for /vol/hostA_sap_archivevol_CER.
[ INFO] SD-00040: Beginning to discover filesystem(s) upon host volume group hostA-3_SdDg.
[ INFO] SD-00041: Finished discovering filesystem(s) upon host volume group hostA-3_SdDg.
[ INFO] SD-00040: Beginning to discover filesystem(s) upon host volume group hostA-2_SdDg.
[ INFO] SD-00041: Finished discovering filesystem(s) upon host volume group hostA-2_SdDg.
[ INFO] SD-00040: Beginning to discover filesystem(s) upon host volume group hostA_s_SdDg.
[ INFO] SD-00041: Finished discovering filesystem(s) upon host volume group hostA_s_SdDg.
[ INFO] SD-00040: Beginning to discover filesystem(s) upon host volume group hostA-1_SdDg.
[ INFO] SD-00041: Finished discovering filesystem(s) upon host volume group hostA-1_SdDg.
[ WARN] SMSAP-05071: Database profile profileA is not eligible for fast restore: Restore Plan:
Preview:
The following components will be restored completely via: host side file copy restore
/vol/hostA_sap_datavol_CER/CER/sapdata1/oradata/CER/sysaux01.dbf
/vol/hostA_sap_datavol_CER/CER/sapdata1/oradata/CER/system01.dbf
/vol/hostA_sap_datavol_CER/CER/sapdata1/oradata/CER/undotbs01.dbf
/vol/hostA_sap_datavol_CER/CER/sapdata1/oradata/CER/users01.dbf
Analysis:
The following reasons prevent certain components from being restored completely via: storage side file system restore
* Files in file system /vol/hostA_sap_datavol_CER not part of the restore scope will be reverted.
* File systems in volume group hostA-1_SdDg not part of the restore scope will be reverted: [/vol/hostA_sap_datavol_CER]
Components not in restore scope:
/vol/hostA_sap_datavol_CER/CER/sapdata1/cfgtoollogs/catbundle/catbundle_PSU_CER_APPLY_2011Dec15_00_52_21.log
/vol/hostA_sap_datavol_CER/CER/sapdata1/cfgtoollogs/catbundle/catbundle_PSU_CER_GENERATE_2011Dec15_00_52_16.log
Components to restore:
* Reasons denoted with an asterisk (*) are overridable.
[ INFO] SMSAP-07433: Returning the database to its initial state: CER (OPEN).
[ INFO] SMSAP-13048: Profile Verify Operation Status: SUCCESS
[ INFO] SMSAP-13049: Elapsed Time: 0:01:17.857
Operation Id [Nab0240e8200dae6f17ecf21060bc6de8] succeeded.
