Upgrade Astra Control Center
To upgrade Astra Control Center, download the installation images and complete these instructions. You can use this procedure to upgrade Astra Control Center in internet-connected or air-gapped environments.
These instructions describe the upgrade process for Astra Control Center from the second-most recent release to this current release. You cannot upgrade directly from a version that is two or more releases behind the current release. If your installed Astra Control Center version is many versions behind the latest release, you might need to perform chain upgrades to more recent versions until your installed Astra Control Center is only one version behind the latest release. For a complete list of released versions, see the release notes.
Before you upgrade, ensure your environment still meets the minimum requirements for Astra Control Center deployment. Your environment should have the following:
An enabled Astra Control Provisioner with Astra Trident running
Determine the Astra Trident version you are running:
kubectl get tridentversion -n tridentIf you are running Astra Trident 23.01 or earlier, use these instructions to upgrade to a more recent version of Astra Trident before upgrading to the Astra Control Provisioner. You can perform a direct upgrade to Astra Control Provisioner 24.02 if your Astra Trident is within a four-release window of version 24.02. For example, you can directly upgrade from Astra Trident 23.04 to Astra Control Provisioner 24.02. -
Verify that Astra Control Provisioner has been enabled. Astra Control Provisioner will not work with releases of Astra Control Center earlier than 23.10. Upgrade your Astra Control Provisioner so that it has the same version as the Astra Control Center you are upgrading to access the latest functionality.
A supported Kubernetes distribution
Determine the Kubernetes version you are running:
kubectl get nodes -o wide -
Sufficient cluster resources
Determine available cluster resources:
kubectl describe node <node name> -
A default storage class
Determine your default storage class:
kubectl get storageclass -
Healthy and available API services
Ensure all API services are in a healthy state and available:
kubectl get apiservices -
(Local registries only) A local registry you can use to push and upload Astra Control Center images
(OpenShift only) Healthy and available cluster operators
Ensure all cluster operators are in a healthy state and available.
kubectl get clusteroperators
You should also consider the following:
Perform upgrades in a maintenance window when schedules, backups, and snapshots are not running. |
Access to the NetApp Astra Control image registry:
You have the option to obtain installation images and functionality enhancements for Astra Control, such as Astra Control Provisioner, from the NetApp image registry.-
Record your Astra Control account ID that you'll need to log in to the registry.
You can see your account ID in the Astra Control Service web UI. Select the figure icon at the top right of the page, select API access, and write down your account ID.
From the same page, select Generate API token and copy the API token string to the clipboard and save it in your editor.
Log into the Astra Control registry:
docker login cr.astra.netapp.io -u <account-id> -p <api-token>
Istio service mesh deployments
If you installed an Istio service mesh during Astra Control Center installation, this upgrade of Astra Control Center will include Istio service mesh. If you do not yet have a service mesh, you can only install one during an initial deployment of Astra Control Center.
The Astra Control Center upgrade process guides you through the following high-level steps:
Log out of your Astra Control Center UI before you begin the upgrade. |
Do not delete the Astra Control Center operator (for example, kubectl delete -f astra_control_center_operator_deploy.yaml) at any time during the Astra Control Center upgrade or operation to avoid deleting pods.
Download and extract Astra Control Center
Download the Astra Control Center images from one of the following locations:
Astra Control Service image registry: Use this option if you don't use a local registry with the Astra Control Center images or if you prefer this method to the bundle download from the NetApp Support Site.
NetApp Support Site: Use this option if you use a local registry with the Astra Control Center images.
Log in to Astra Control Service.
On the Dashboard, select Deploy a self-managed instance of Astra Control.
Follow the instructions to log in to the Astra Control image registry, pull the Astra Control Center installation image, and extract the image.
Download the bundle containing Astra Control Center (
astra-control-center-[version].tar.gz) from the Astra Control Center downloads page. -
(Recommended but optional) Download the certificates and signatures bundle for Astra Control Center (
astra-control-center-certs-[version].tar.gz) to verify the signature of the bundle.tar -vxzf astra-control-center-certs-[version].tar.gzopenssl dgst -sha256 -verify certs/AstraControlCenter-public.pub -signature certs/astra-control-center-[version].tar.gz.sig astra-control-center-[version].tar.gzThe output will show
Verified OKafter successful verification. -
Extract the images from the Astra Control Center bundle:
tar -vxzf astra-control-center-[version].tar.gz
Complete additional steps if you use a local registry
If you are planning to push the Astra Control Center bundle to your local registry, you need to use the NetApp Astra kubectl command line plugin.
Remove the NetApp Astra kubectl plugin and install it again
You need to use the latest version of the NetApp Astra kubectl command line plugin to push images to a local Docker repository.
Determine if you have the plug-in installed:
kubectl astra -
Take one of these actions:
If the plugin is installed, the command should return the kubectl plugin help and you can remove the existing version of kubectl-astra:
delete /usr/local/bin/kubectl-astra. -
If the command returns an error, the plugin is not installed and you can proceed to the next step to install it.
Install the plugin:
List the available NetApp Astra kubectl plugin binaries, and note the name of the file you need for your operating system and CPU architecture:
The kubectl plugin library is part of the tar bundle and is extracted into the folder kubectl-astra.ls kubectl-astra/ -
Move the correct binary into the current path and rename it to
kubectl-astra:cp kubectl-astra/<binary-name> /usr/local/bin/kubectl-astra
Add the images to your registry
If you are planning to push the Astra Control Center bundle to your local registry, complete the appropriate step sequence for your container engine:
Docker-
Change to the root directory of the tarball. You should see the
acc.manifest.bundle.yamlfile and these directories:acc/
kubectl-astra/
acc.manifest.bundle.yaml -
Push the package images in the Astra Control Center image directory to your local registry. Make the following substitutions before running the
push-imagescommand:-
Replace <BUNDLE_FILE> with the name of the Astra Control bundle file (
acc.manifest.bundle.yaml). -
Replace <MY_FULL_REGISTRY_PATH> with the URL of the Docker repository; for example, "https://<docker-registry>".
Replace <MY_REGISTRY_USER> with the user name.
Replace <MY_REGISTRY_TOKEN> with an authorized token for the registry.
kubectl astra packages push-images -m <BUNDLE_FILE> -r <MY_FULL_REGISTRY_PATH> -u <MY_REGISTRY_USER> -p <MY_REGISTRY_TOKEN>
Podman-
Change to the root directory of the tarball. You should see this file and directory:
acc/
kubectl-astra/
Log in to your registry:
podman login <YOUR_REGISTRY> -
Prepare and run one of the following scripts that is customized for the version of Podman you use. Substitute <MY_FULL_REGISTRY_PATH> with the URL of your repository that includes any sub-directories.
Podman 4export REGISTRY=<MY_FULL_REGISTRY_PATH> export PACKAGENAME=acc export PACKAGEVERSION=24.02.0-69 export DIRECTORYNAME=acc for astraImageFile in $(ls ${DIRECTORYNAME}/images/*.tar) ; do astraImage=$(podman load --input ${astraImageFile} | sed 's/Loaded image: //') astraImageNoPath=$(echo ${astraImage} | sed 's:.*/::') podman tag ${astraImageNoPath} ${REGISTRY}/netapp/astra/${PACKAGENAME}/${PACKAGEVERSION}/${astraImageNoPath} podman push ${REGISTRY}/netapp/astra/${PACKAGENAME}/${PACKAGEVERSION}/${astraImageNoPath} donePodman 3export REGISTRY=<MY_FULL_REGISTRY_PATH> export PACKAGENAME=acc export PACKAGEVERSION=24.02.0-69 export DIRECTORYNAME=acc for astraImageFile in $(ls ${DIRECTORYNAME}/images/*.tar) ; do astraImage=$(podman load --input ${astraImageFile} | sed 's/Loaded image: //') astraImageNoPath=$(echo ${astraImage} | sed 's:.*/::') podman tag ${astraImageNoPath} ${REGISTRY}/netapp/astra/${PACKAGENAME}/${PACKAGEVERSION}/${astraImageNoPath} podman push ${REGISTRY}/netapp/astra/${PACKAGENAME}/${PACKAGEVERSION}/${astraImageNoPath} doneThe image path the script creates should resemble the following, depending on your registry configuration: https://downloads.example.io/docker-astra-control-prod/netapp/astra/acc/24.02.0-69/image:version
Change the directory:
cd manifests
Install the updated Astra Control Center operator
(Local registries only) If you are using a local registry, complete these steps:
Open the Astra Control Center operator deployment YAML:
vim astra_control_center_operator_deploy.yamlAn annotated sample YAML follows these steps. -
If you use a registry that requires authentication, replace or edit the default line of
imagePullSecrets: []with the following:imagePullSecrets: [{name: astra-registry-cred}] -
Change
ASTRA_IMAGE_REGISTRYfor thekube-rbac-proxyimage to the registry path where you pushed the images in a previous step. -
Change
ASTRA_IMAGE_REGISTRYfor theacc-operatorimage to the registry path where you pushed the images in a previous step. -
Add the following values to the
envsection:- name: ACCOP_HELM_UPGRADETIMEOUT value: 300m
apiVersion: apps/v1 kind: Deployment metadata: labels: control-plane: controller-manager name: acc-operator-controller-manager namespace: netapp-acc-operator spec: replicas: 1 selector: matchLabels: control-plane: controller-manager strategy: type: Recreate template: metadata: labels: control-plane: controller-manager spec: containers: - args: - --secure-listen-address=0.0.0.0:8443 - --upstream=http://127.0.0.1:8080/ - --logtostderr=true - --v=10 image: ASTRA_IMAGE_REGISTRY/kube-rbac-proxy:v4.8.0 name: kube-rbac-proxy ports: - containerPort: 8443 name: https - args: - --health-probe-bind-address=:8081 - --metrics-bind-address=127.0.0.1:8080 - --leader-elect env: - name: ACCOP_LOG_LEVEL value: "2" - name: ACCOP_HELM_UPGRADETIMEOUT value: 300m image: ASTRA_IMAGE_REGISTRY/acc-operator:24.02.68 imagePullPolicy: IfNotPresent livenessProbe: httpGet: path: /healthz port: 8081 initialDelaySeconds: 15 periodSeconds: 20 name: manager readinessProbe: httpGet: path: /readyz port: 8081 initialDelaySeconds: 5 periodSeconds: 10 resources: limits: cpu: 300m memory: 750Mi requests: cpu: 100m memory: 75Mi securityContext: allowPrivilegeEscalation: false imagePullSecrets: [] securityContext: runAsUser: 65532 terminationGracePeriodSeconds: 10 -
Install the updated Astra Control Center operator:
kubectl apply -f astra_control_center_operator_deploy.yamlSample response:
namespace/netapp-acc-operator unchanged customresourcedefinition.apiextensions.k8s.io/astracontrolcenters.astra.netapp.io configured role.rbac.authorization.k8s.io/acc-operator-leader-election-role unchanged clusterrole.rbac.authorization.k8s.io/acc-operator-manager-role configured clusterrole.rbac.authorization.k8s.io/acc-operator-metrics-reader unchanged clusterrole.rbac.authorization.k8s.io/acc-operator-proxy-role unchanged rolebinding.rbac.authorization.k8s.io/acc-operator-leader-election-rolebinding unchanged clusterrolebinding.rbac.authorization.k8s.io/acc-operator-manager-rolebinding configured clusterrolebinding.rbac.authorization.k8s.io/acc-operator-proxy-rolebinding unchanged configmap/acc-operator-manager-config unchanged service/acc-operator-controller-manager-metrics-service unchanged deployment.apps/acc-operator-controller-manager configured
Verify pods are running:
kubectl get pods -n netapp-acc-operator
Edit the Astra Control Center custom resource (CR):
kubectl edit AstraControlCenter -n [netapp-acc or custom namespace]An annotated sample YAML follows these steps. -
Change the Astra version number (
astraVersioninside ofspec) from23.10.0to24.02.0:You cannot upgrade directly from a version that is two or more releases behind the current release. For a complete list of released versions, see the release notes. spec: accountName: "Example" astraVersion: "[Version number]"
Change the image registry:
(Local registries only) If you are using a local registry, verify that your image registry path matches the registry path you pushed the images to in a previous step. Update
imageRegistryinside ofspecif the local registry has changed since your last installation. -
(Astra Control image registry) Use the Astra Control image registry (
cr.astra.netapp.io) you used to download the updated Astra Control bundle.imageRegistry: name: "[cr.astra.netapp.io or your_registry_path]"
Add the following to your
crdsconfiguration inside ofspec:crds: shouldUpgrade: true -
Add the following lines within
additionalValuesinside ofspecin the Astra Control Center CR:additionalValues: nautilus: startupProbe: periodSeconds: 30 failureThreshold: 600 keycloak-operator: livenessProbe: initialDelaySeconds: 180 readinessProbe: initialDelaySeconds: 180 -
Save and exit the file editor. The changes will be applied and the upgrade will begin.
(Optional) Verify that the pods terminate and become available again:
watch kubectl get pods -n [netapp-acc or custom namespace] -
Wait for the Astra Control status conditions to indicate that the upgrade is complete and ready (
True):kubectl get AstraControlCenter -n [netapp-acc or custom namespace]Response:
NAME UUID VERSION ADDRESS READY astra 9aa5fdae-4214-4cb7-9976-5d8b4c0ce27f 24.02.0-69 10.111.111.111 True
To monitor upgrade status during the operation, run the following command: kubectl get AstraControlCenter -o yaml -n [netapp-acc or custom namespace]To inspect the Astra Control Center operator logs, run the following command:
kubectl logs deploy/acc-operator-controller-manager -n netapp-acc-operator -c manager -f
Verify system status
Log in to Astra Control Center.
Verify that the version has been upgraded. See the Support page in the UI.
Verify that all your managed clusters and apps are still present and protected.
