Known issues
Known issues identify problems that might prevent you from using this release of the product successfully.
The following known issues affect the current release:
App backups and snapshots fail if the volumesnapshotclass is added after a cluster is managed
App data management operations fail with Internal Service Error (500) when Astra Trident is offline
Restoring from a backup when using Kerberos in-flight encryption can fail
Backup data remains in bucket after deletion for buckets with expired retention policy
Backups and snapshots fail with a UI 500 error in this scenario. As a workaround, refresh the app list.
Managing a cluster with Astra Control Center fails when kubeconfig file contains more than one context
You cannot use a kubeconfig with more than one cluster and context in it. See the knowledgebase article for more information.
If Astra Trident on an app cluster goes offline (and is brought back online) and 500 internal service errors are encountered when attempting app data management, restart all of the Kubernetes nodes in the app cluster to restore functionality.
When you restore an application from a backup to a storage backend that is using Kerberos in-flight encryption, the restore operation can fail. This issue does not affect restoring from a snapshot or replicating the application data using NetApp SnapMirror.
When using Kerberos in-flight encryption with NFSv4 volumes, ensure that the NFSv4 volumes are using the correct settings. Refer to the NetApp NFSv4 Domain Configuration section (page 13) of the NetApp NFSv4 Enhancements and Best Practices Guide. |
If you delete an app's immutable backup after the bucket's retention policy has expired, the backup is deleted from Astra Control but not from the bucket. This issue will be fixed in an upcoming release.
