Collecting and assessing the inventory information
PDF of this doc site
- Copy-based transition
- Copy-free transition
Creating your file...
Your file is ready
You can collect inventory information from controllers, hosts, and FC switches. You can then assess features and functionalities of these systems, and identify how these features and functionalities work in the ONTAP version that is selected for transition.
You can collect inventory information in two ways:
If your environment security allows it, you can install the 7-Mode Transition Tool, and then use it to collect the inventory information.
You can import the inventory XML report generated by the Inventory Collect Tool, and then perform the assessment.
In both cases, you must use Inventory Collect Tool 3.3 to collect the inventory.
