ONTAP 7-Mode Transition
Port requirements for communicating with the 7-Mode Transition Tool
Contributors netapp-barbe
The 7-Mode Transition Tool communicates with the 7-Mode system and the cluster over certain ports. You must ensure that these ports on the 7-Mode system and the cluster are open to allow communication with the 7-Mode Transition Tool.
Ports that must be open on the 7-Mode systems
The 7-Mode Transition Tool communicates with the 7-Mode systems by using HTTPS on port 443.
Ports that must be open on the cluster
The 7-Mode Transition Tool communicates with the cluster by using HTTPS on port 443.
Ports that must be open on the 7-Mode Transition Tool
Port 8444 of the 7-Mode Transition Tool must be open for the web interface.
To transition netgroups and CIFS local users and groups, the following requirements must be met:
  • Port 8088 of the 7-Mode Transition Tool must be available.
    For an alternative to port 8088, you must change the port specified by the tool.http.port parameter in the transition-tool.conf file of the 7-Mode Transition Tool installation directory.
    Note You must restart the 7-Mode Transition Tool service after changing the port in the configuration file.
  • Each node in the cluster must have at least one data LIF configured for the target SVM.
  • All SVM data LIFs must be able to communicate with the 7-Mode Transition Tool port 8088 or the port specified by the tool.http.port parameter in the transition-tool.conf file.
    Note You must verify that firewalls do not block this traffic.
Related information
