ONTAP 7-Mode Transition
Preparing RHEL LUNs with mount points using DMMP device names for transition using the Inventory Assessment Workbook
Before transition of a LUN with a mount point using a DMMP device name, you must replace the DMMP device name with its respective file system UUID number. This applies to Red Hat Enterprise Linux (RHEL) 5 and RHEL 6.
This procedure applies to copy-based transitions and copy-free transitions.
Steps
  1. Gather pretransition information from the Inventory Assessment Workbook.
    Specifically, you need the following information:
    • The file system configured on the DMMP device
    • The directory on which the DMMP device is mounted
    • The file system UUID for the DMMP device
Steps
  1. Verify that the mount points for the DMMP device are defined in the `/etc/fstab `file.
  2. Create a backup of the file:
    cp /etc/fstab /etc/fstab_pre_transition
  3. Edit the /etc/fstab file to replace the DMMP device name with its respective file system UUID number.
    In the following example, the DMMP device /dev/mapper/360a9800037534562572b453855496b41 is replaced by UUID a073547e-00b6-4bf9-8e08-5eef08499a9c:
    [root@IBMx3550M3-229-169 ~]# cat /etc/fstab
    /dev/VolGroup00/LogVol00 /  ext3  defaults   1 1
    LABEL=/boot /boot  ext3     defaults         1 2
    tmpfs  /dev/shm    tmpfs    defaults         0 0
    devpts /dev/pts    devpts   gid=5, mode=620  0 0
    sysfs  /sys	       sysfs           defaults  0 0
    proc   /proc       proc           defaults   0 0
    /dev/VolGroup00/LogVol01 swap	swap  defaults 0 0
    /dev/mapper/test_vg-test_lv /mnt/lvm_ext3 ext3 defaults,_netdev 0 0
    UUID=a073547e-00b6-4bf9-8e08-5eef08499a9c /mnt/dmmp_ext3 ext3 defaults,_netdev 0 0
Related information
