ONTAP 7-Mode Transition
Commands for managing transition
You can use the transition cbt command to manage functions, such as creating, modifying, deleting, and displaying transition projects.
The following option can be used with all commands:
-r no: Disables the interactive nature of the command. By default, this option is enabled.
You can also use the -v option, which enables the verbose mode, with the transition version and transition cbt menu commands.
Commands to manage transition operations
If you want to…​ Use this command…​
Create a transition project
transition cbt create
Add the cluster information to the given project
transition cbt add-cluster-info
Modify a transition project
transition cbt modify
Complete the transition to an ONTAP storage system
transition cbt cutover
Run precheck on the project
transition cbt precheck
Apply the configurations to an ONTAP storage system
transition cbt precutover
Trigger the SnapMirror resynchronization between the 7-Mode volumes and ONTAP volumes in the project
transition cbt resync
Trigger the SnapMirror update operation for the ONTAP volumes
transition cbt update
Display the version of 7-Mode Transition Tool
transition cbt version
Start baseline data copy from the 7-Mode volumes to ONTAP volumes in a project
transition cbt start
Pause data copy from the 7-Mode volumes to ONTAP volumes in a project
transition cbt pause
Resume data copy transfers from the 7-Mode volumes to ONTAP volumes of a paused project
transition cbt resume
Abort a transition project
transition cbt abort
Delete a transition project
transition cbt delete
Display the list of transition projects or display information about a project
transition cbt show
Commands to manage volume SnapMirror relationships
Add information about a 7-Mode primary system to a secondary project
Add information about an ONTAP secondary system to a primary project
Remove information about a 7-Mode primary system from a secondary project
transition cbt remove-primary-seven-mode-system
Remove information about an ONTAP secondary system from a primary project
transition cbt remove-secondary-cluster-mode-system
List the 7-Mode primary systems added to a secondary project
transition cbt show-primary-seven-mode-systems
List the ONTAP secondary systems added to a primary project
transition cbt show-secondary-cluster-mode-systems
Commands to manage credentials of Data ONTAP systems
Save credentials (user name and password) of a host in the transition server
transition credentials add
Retrieve user name of a host
transition credentials get
Modify the user name or password of a host
transition credentials modify
Delete credentials of a host from the transition server
transition credentials remove
Commands to manage the volume pairs in a project
Add the 7-Mode volume and the ONTAP volume (volume pair) to a project
transition cbt volumepair add
Modify the ONTAP volume of a project
transition cbt volumepair modify
Remove a volume pair from a project
transition cbt volumepair remove
List volume pairs in a project
transition cbt volumepair show
Commands to manage LIF details
Note FC and iSCSI LIFs are not transitioned by the 7-Mode Transition Tool.
Add anSVM data LIF to a project
transition cbt lif add
Modify anSVM data LIF of a project
transition cbt lif modify
Remove LIFs from a project
transition cbt lif remove
List all the LIFs added to a project
transition cbt lif show
Commands to manage project properties
Set value for a specific project property
transition cbt property-set
Clear the value of a specific project property
transition cbt property-reset
Get the value of a specific project property
transition cbt property-get
Commands to manage transition jobs
List jobs that ran or are running on the given project and operation
transition jobs
View the status of a job
transition job-status
View the results of a job
transition job-results
Commands to manage transition schedules
Add a schedule to manage SnapMirror transfers along with bandwidth
transition cbt schedule add
Modify a SnapMirror schedule of the project
transition cbt schedule modify
Remove the SnapMirror schedules from the project
transition cbt schedule remove
List all the SnapMirror schedules in a project
transition cbt schedule show
Command to collect tool logs
Collect the log files of 7-Mode Transition Tool Logs are saved on the server in the asup directory of the 7-Mode Transition Tool installation path.
transition bundle-tool-logs
For more information about these commands, see the man pages for the 7-Mode Transition Tool CLI.
Related information
