Preparing to transition Solaris host LUNs with Sun Volume Manager
Before you transition Solaris host data LUNs with Sun Volume Manager from ONTAP operating in 7-Mode to clustered ONTAP, you must gather information you need for the transition process.
This task applies to copy-based transitions and copy-free transitions.
Steps
Display your LUNs to identify the name of the LUNs to be transitioned:
lun showfas8040-shu01> lun show /vol/ufs/ufs1 5g (5368709120) (r/w, online, mapped) /vol/ufs/ufs2 5g (5368709120) (r/w, online, mapped) /vol/zfs/zfs1 6g (6442450944) (r/w, online, mapped) /vol/zfs/zfs2 6g (6442450944) (r/w, online, mapped) -
On the host, locate the device file name for the LUN:
#sanlun lun showThe device file name is listed in the
device filenamecolumn.# sanlun lun show controller(7mode)/ device host lun vserver(Cmode) lun-pathname filename adapter protocol size mode -------------------------------------------------------------------------------------------------------------------------- fas8040-shu01 /vol/zfs/zfs2 /dev/rdsk/c0t60A98000383035356C2447384D396550d0s2 scsi_vhci0 FCP 6g 7 fas8040-shu01 /vol/zfs/zfs1 /dev/rdsk/c0t60A98000383035356C2447384D39654Ed0s2 scsi_vhci0 FCP 6g 7 fas8040-shu01 /vol/ufs/ufs2 /dev/rdsk/c0t60A98000383035356C2447384D39654Ad0s2 scsi_vhci0 FCP 5g 7 fas8040-shu01 /vol/ufs/ufs1 /dev/rdsk/c0t60A98000383035356C2447384D396548d0s2 scsi_vhci0 FCP 5g
List and record the SVM, and then get the disks associated with the SVM:
metasetmetaset -s set-name# metaset Set name = svm, Set number = 1 Host Owner Solarisx2-shu04 Yes Drive Dbase /dev/dsk/c0t60A98000383035356C2447384D39654Ad0 Yes /dev/dsk/c0t60A98000383035356C2447384D396548d0 Yes
# metastat -s svm svm/d2: Concat/Stripe Size: 10452992 blocks (5.0 GB) Stripe 0: Device Start Block Dbase Reloc /dev/dsk/c0t60A98000383035356C2447384D396548d0s0 0 No Yes svm/d1: Concat/Stripe Size: 10452992 blocks (5.0 GB) Stripe 0: Device Start Block Dbase Reloc /dev/dsk/c0t60A98000383035356C2447384D39654Ad0s0 0 No Yes Device Relocation Information: Device Reloc Device ID /dev/dsk/c0t60A98000383035356C2447384D396548d0 Yes id1,sd@n60a98000383035356c2447384d396548 /dev/dsk/c0t60A98000383035356C2447384D39654Ad0 Yes id1,sd@n60a98000383035356c2447384d39654a -
List and record the mount points:
df –ah# df -ah Filesystem size used avail capacity Mounted on /dev/md/svm/dsk/d1 4.9G 1.5G 3.4G 31% /d1 /dev/md/svm/dsk/d2 4.9G 991M 3.9G 20% /d2
