ONTAP 7-Mode Transition
SAN transition: supported and unsupported configurations, and required manual steps
Contributors netapp-barbe
You must be aware of the SAN configurations that are transitioned by the 7-Mode Transition Tool. You should also be aware of the 7-Mode SAN features that are not supported in ONTAP, so that you can take any necessary actions before the transition.
You should verify all of the precheck error and warning messages to evaluate the impact of such configurations on transition.
Configurations that are transitioned
The following SAN configurations are transitioned by the 7-Mode Transition Tool:
  • FC and iSCSI services
  • igroups and LUN maps
    Note
    • 7-Mode igroups that are not mapped to any LUNs are not transitioned to the target SVMs.
    • For clustered Data ONTAP 8.3.0 and 8.3.1, the transition of igroups and LUN mapping configurations is not supported during the precutover operation.
      Instead, the required igroups are created during the cutover operation. For primary and stand-alone volumes, LUNs are mapped to igroups during the cutover operation. However, for secondary volumes, the mapping of LUNs to igroups is not supported during the cutover operation. You must manually map the secondary LUNs after completing the transition of primary volumes.
    • For ONTAP 8.3.2 and later supported releases, igroups and LUN mapping configurations are applied during the precutover operation.
Unsupported configurations in ONTAP
The unsupported configurations in ONTAP are as follows:
  • 7-Mode Snapshot copy-backed LUN clones
    Snapshot copy-backed LUN clones present in the Snapshot copies are not supported for any restore operation. These LUNs are not accessible in ONTAP. You must split or delete the 7-Mode Snapshot copy-backed LUN clones before transition.
  • LUNs with an ostype parameter value of vld, image, or any user-defined string
    You must either change the value of the ostype parameter for such LUNs or delete the LUNs before transition.
  • LUN clone split
    You must either wait for the active LUN clone split operations to finish or abort the LUN clone split and delete the LUN before transition.
The following 7-Mode features enable you to continue with the transition process, but are not supported in ONTAP:
  • The lun share command
    Sharing a LUN over NAS protocols
  • SnapValidator
Configurations that must be manually transitioned
The following configurations must be transitioned manually:
  • SAN LIFs
    You must manually create the LIFs before transition.
  • Portsets
    You must manually configure igroups that are bound to a portset after transition.
  • iSCSI access list information
  • iSNS configuration
  • iSCSI CHAP and RADIUS configurations
Related information
