Determine your ASA r2 system storage limits
Contributors netapp-aherbin
Knowing the storage limits of your ASA r2 system helps you configure it for optimal performance and support. You can look up the limits for your system and ONTAP version in NetApp Hardware Universe.
Limits might vary based on your ASA r2 system and your ONTAP version. Refer to NetApp Hardware Universe for a complete list of the most current limits for your specific system.
Note Virtual machine (VM) limits are not listed in Hardware Universe. The recommended maximum number of VMs per HA pair is 800 and per cluster is 1,200 based on ASA r2 system volume limits. This limit does not apply to VMs residing in VMFS datastores. There is no maximum number of VMs for VMFS datastores.
About this task
ASA r2 systems are listed in NetApp Hardware Universe under Products as "ASA" platforms.
Steps
  1. Go to NetApp Hardware Universe.
  2. Select Products.
  3. Under Platforms, select ASA as your system type.
  4. Select your specific system, and then select your ONTAP version.
  5. Select Show Results.
Results
The supported limits for your specific ASA r2 system and ONTAP version are displayed.
