Update firmware on ASA r2 storage systems
ONTAP automatically downloads and updates firmware and system files on your ASA r2 system by default. If you want the flexibility of viewing recommended updates before they are downloaded and installed, you can use System Manager to disable automated updates or to edit update parameters so that you are notified of available updates before any action is performed.
Enable automatic updates
Recommended updates for storage firmware, Service Processor/Baseboard Management Controller (SP/BMC) firmware, and system files are automatically downloaded and installed on your ASA r2 system by default. If automatic updates have been disabled, you can enable them to reinstate the default behavior.
In System Manager, select Cluster > Settings.
Under Software updates, select Enable.
Read the EULA.
Accept the defaults to Show notification of recommended updates. Optionally, select to Automatically update or to Automatically dismiss recommended updates.
Select to acknowledge that your update modifications will be applied to all current and future updates.
Select Save.
Recommended updates are automatically downloaded and installed on your ASA r2 system based on your update selections.
Disable automatic updates
Disable automatic updates only if you want to manage updates entirely yourself. With automatic updates turned off, the system will not notify, download, or install updates. You are responsible for monitoring, downloading, scheduling, and installing all updates manually.
Under Software updates, select Disable.
Automatic updates are disabled. You should regularly check for recommended updates and decide if you want to perform a manual installation.
View automatic updates
View a list of firmware and system file updates that have been downloaded to your cluster and are scheduled for automatic installation. Also view updates that have been previously automatically installed.
Next to Software updates select
, then select View all automatic updates.
Edit automatic updates
You can have recommended updates for your storage firmware, SP/BMC firmware, and system files automatically downloaded and installed on your cluster, or automatically dismissed. To control installation or dismissal manually, choose to be notified when a recommended update is available, and then install or dismiss it yourself.
, then select All other updates. -
Update the selections for automatic updates.
Select Save.
Automatic updates are modified based on your selections.
Update firmware manually
To view recommended updates before they are downloaded and installed, disable automatic updates and update your firmware manually.
Download your firmware update file to a server or local client.
In System Manager, select Cluster > Overview, then select All other updates.
Under Manual Updates, select Add firmware files; then select Download from the server or Upload from the local client.
Install the firmware update file.
Your firmware is updated.
