Manage security certificates on ASA r2 storage systems
Use digital security certificates to verify the identity of remote servers.
Online Certificate Status Protocol (OCSP) validates the status of digital certificate requests from ONTAP services using SSL and Transport Layer Security (TLS) connections.
Modify certificate expiration alerts
Beginning with ONTAP 9.20.1, System Manager displays a dashboard health alert 30 days before a cluster or storage virtual machine (VM) certificate expires. The alert is updated daily to show the number of days remaining until expiration. You can modify the default alert threshold to any value from 0 to 90 days, disable it so that no alerts are displayed, or suppress alerts for already expired certificates while continuing to receive alerts for upcoming expirations.
In System Manager, select Cluster > Settings.
Under Security, next to Certificates, select
Select Client/server certificates.
Update the expiry warning threshold, disable, or suppress it:
Update the Warning Threshold to any number of days from 0 to 90.
Select Disable Expiry Warnings to disable the alert.
Select Suppress Expired Alerts to hide alerts for already expired certificates while continuing to receive alerts for upcoming expirations.
Generate a certificate signing request
Generate a certificate signing request (CSR) to create a private key that can be used to generate a public certificate.
; then select
Enter the subject common name; then select the country.
If you want to change the CSR defaults, select extended key usage, or add subject alternative names, select
; then make the desired updates. -
Select Generate.
You have generated a CSR that can be used to generate a public certificate.
Add a trusted certificate authority
ONTAP provides a default set of trusted root certificates for applications using Transport Layer Security (TLS). You can add additional trusted certificate authorities as needed.
Select Cluster > Settings.
Select Trusted certificate authorities.
Enter or import the certificate details; then select
You have added a new trusted certificate authority to your ASA r2 system.
Renew or delete a trusted certificate authority
Trusted certificate authorities must be renewed annually. If you do not want to renew an expired certificate, you should delete it.
Select the trusted certificate authority that you want to renew or delete.
Renew or delete the certificate authority.
To renew the certificate authority, do this… To delete the certificate authority, do this… -
Select
; then select Renew. -
Enter or import the certificate information; then select Renew.
Select
; then select Delete. -
Confirm that you want to delete; then select Delete.
You have renewed or deleted an existing trusted certificate authority on your ASA r2 system.
Add a client/server certificate or local certificate authorities
Add a client/server certificate or local certificate authorities to enable secure web services.
Select Client/server certificates or Local certificate authorities.
Add the certificate information; then select
You have added a new client/server certificate or local authorities to your ASA r2 system.
Renew or delete a client/server certificate or local certificate authorities
Client/server certificates and local certificate authorities must be renewed annually. If you do not want to renew an expired certificate or local certificate authorities, you should delete them.
Select Client/server certificates, or Local certificate authorities.
Select the certificate you want to renew or delete.
Select
Select
You have renewed or deleted an existing client/server certificate or local certificate authority on your ASA r2 system.
