Migrate ONTAP data encryption keys between key managers on ASA r2 systems
You can manage data encryption keys with the ONTAP onboard key manager on your ASA r2 system, an external key manager, or both in supported configurations. External key managers are supported only at the storage VM level. At the ONTAP cluster level, you can use either the onboard key manager or an external key manager.
| If you enable your key manager at the… | You can use… |
Cluster level only |
Either the onboard key manager or an external key manager |
Storage VM level only |
An external key manager only |
Both the cluster and storage VM level |
One of the following key manager combinations:
Migrate keys between key managers at the ONTAP cluster level
Beginning with ONTAP 9.16.1, you can use the ONTAP command line interface (CLI) to migrate keys between key managers at the cluster level.
Set the privilege level to advanced:
set -privilege advanced -
Create an inactive external key manager configuration:
security key-manager external create-config -
Switch to the external key manager:
security key-manager keystore enable -vserver <storage_vm_name> -type KMIP -
Delete the onboard key manager configuration:
security key-manager keystore delete-config -vserver <storage_vm_name> -type OKM -
Set the privilege level to admin:
set -privilege admin
Create an inactive onboard key manager configuration:
security key-manager onboard create-config -
Enable the onboard key manager configuration:
security key-manager keystore enable -vserver <storage_vm_name> -type OKM -
Delete the external key manager configuration
security key-manager keystore delete-config -vserver <storage_vm_name> -type KMIP -
Migrate keys between key managers across ONTAP cluster and storage VM levels
You can use the ONTAP command line interface (CLI) to migrate keys between key managers at the cluster and storage VM levels.
Migrate the keys:
security key-manager key migrate -from-vserver <storage_vm_name> -to-vserver <storage_vm_name> -
