View cluster events and jobs on ASA r2 storage systems
Contributors netapp-aherbin
Use ONTAP System Manager to view a list of errors or alerts, recommended corrective actions, system audit logs, and active, completed, or failed jobs.
Steps
  1. In System Manager, select Events & Jobs.
  2. View cluster events and jobs.
    To view this…​ Do this…​
    Cluster events
    Select Events; then select Event log.
    Active IQ suggestions
    Select Events; then select Active IQ suggestions.
    System alerts
    1. Select System alerts.
    2. Select the system alert for which you want to take action.
    3. Acknowledge or suppress the alert.
    Cluster jobs
    Select Jobs.
    Audit logs
    Select Audit logs.
Send email notifications for cluster events and audit logs
Configure your system to send a notification to specific email addresses when there is a cluster event or audit log entry.
Steps
  1. In System Manager, select Cluster > Settings.
  2. Next to Notifications management, select three vertical blue dots.
  3. To configure an event destination, select View event destinations; then select Event destinations. To configure an audit log destination, select View audit destinations; then select Audit log destinations.
  4. Select blue rectangle with plus sign followed by the word add in white letters.
  5. Enter the destination information; then select Add.
Result
The email address you added receives the specified email notifications for cluster events and audit logs.
