Astra Automation
Manage a cluster
Contributors dmp-netapp
You can manage a Kubernetes cluster so that data protection can be performed.
1. Select the cluster to manage
Perform the workflow List clusters and select the desired cluster. The property managedState of the cluster must be unmanaged.
2. Optionally select the storage class
Optionally perform the workflow List storage classes and select the desired storage class.
Note If you don't provide a storage class on the call to manage the cluster, your default storage class will be used.
3. Manage the cluster
Perform the following REST API call to manage the cluster.
HTTP method Path
POST
/accounts/{account_id}/topology/v1/managedClusters
JSON input example
  "type": "application/astra-managedCluster",
  "version": "1.0",
  "id": "d0fdf455-4330-476d-bb5d-4d109714e07d"
Curl example
curl --location -i --request POST 'https://astra.netapp.io/accounts/<ACCOUNT_ID>/topology/v1/managedClusters' --header 'Accept: */*' --header 'Authorization: Bearer <API_TOKEN>' --data @JSONinput
