The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
Restoring the WFA database using the CLI
PDF of this doc site
Installation and setup for Linux
Installation and setup for Windows
Creating your file...
Your file is ready
During a disaster, while recovering data you can restore the OnCommand Workflow Automation (WFA) database and supported configurations that you backed up previously using the command-line interface (CLI). The supported configurations include data access, HTTP timeout, and SSL certificates.
The following are the two types of restore:
Full restore
Regular restore
