Prerequisites for installing Workflow Automation
Before installing OnCommand Workflow Automation (WFA), you must ensure that you have the required information and you have completed certain tasks.
Before you install WFA on a system, you must have completed the following tasks:
Downloading the WFA installation file from the NetApp Support Site and copying the file to the server on which you want to install WFA
You must have valid credentials to log in to the NetApp Support Site. If you do not have valid credentials, you can register on the NetApp Support Site to obtain the credentials. -
Verifying that the system has access to the following, as applicable:
Storage controllers
Active IQ Unified Manager
If your environment requires Secure Shell (SSH) accessibility, you must ensure that SSH is enabled on the target controllers. |
Verifying that Perl v5.10.1 is installed
Required configuration information
| Unit or system | Details | Purpose | ||
Arrays |
Perform operations on storage systems
External repositories such as OnCommand Balance and custom databases |
Acquire dataYou must create the relevant WFA content, such as dictionary entries and cache queries for the external repositories, in order to acquire data from the external repositories. |
Mail server |
Receive WFA notifications through email |
AutoSupport server |
Send AutoSupport messages through SMTPIf you do not have a mail host configured, you can use HTTP or HTTPS to send AutoSupport messages. |
Microsoft Active Directory (AD) LDAP server |
Authenticate and authorize using AD LDAP or AD LDAPS |
SNMP management application |
Receive WFA SNMP notifications |
Syslog server |
Send log data |
Related information
