Back up SAP HANA resource groups
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
- Protect IBM Db2
- Protect PostgreSQL
Creating your file...
A resource group is a collection of resources on a host. A backup operation on the resource group is performed on all resources defined in the resource group.
In the left navigation pane, select Resources, and then select the appropriate plug-in from the list.
In the Resources page, select Resource Group from the View list.
In the Resource Groups page, select the resource group that you want to back up, and then select Back up Now.
In the Backup page, perform the following steps:
If multiple policies are associated with the resource group, from the Policy drop-down list, select the policy that you want to use for backup.
If the policy selected for the on-demand backup is associated with a backup schedule, the on-demand backups will be retained based on the retention settings specified for the schedule type.
Select Backup.
Monitor the operation progress by selecting Monitor > Jobs.
