Storage types supported by SnapCenter Plug-in for SAP HANA Database
PDF of this doc site
- Protect Microsoft SQL Server databases
- Protect SAP HANA databases
Creating your file...
Your file is ready
SnapCenter supports a wide range of storage types on both physical machines and virtual machines (VMs). You must verify the support for your storage type before installing SnapCenter Plug-in for SAP HANA Database.
Machine | Storage type |
Physical and virtual servers |
FC-connected LUNs |
Physical server |
iSCSI-connected LUNs |
NFS-connected volumes |
