SnapCenter Software 5.0
Add SAP HANA database
Contributors netapp-soumikd
You should add the SAP HANA database manually.
About this task
Resources need to be added manually if the plug-in is installed on a centralized server. If the SAP HANA plug-in is installed on the HANA database host, then the HANA system is discovered automatically.
Note Automatic discovery is not supported for HANA multi-host configuration, they must be added through centralized plug-in only.
Steps
  1. In the left navigation pane, select the SnapCenter Plug-in for SAP HANA Database from the drop-down list, and then click Resources.
  2. In the Resources page, click Add SAP HANA Database.
  3. In the Provide Resource Details page, perform the following actions:
    1. Enter the resource type either as Single Container, Multitenant Database Container, or Non-data Volume.
    2. Enter the SAP HANA system name.
    3. Enter the system ID (SID).
    4. Select the plug-in host.
    5. Enter the key to connect to the SAP HANA system.
    6. Enter the username for whom the HDB Secure User Store Key is configured.
  4. In the Provide Storage Footprint page, select Azure NetApp Files as the storage type.
    1. Select the Azure NetApp account.
    2. Select the capacity pool and the associated volumes.
    3. Click Save.
  5. Review the summary, and then click Finish.
