Set up Azure networking for Cloud Volumes ONTAP
The NetApp Console handles the set up of networking components for Cloud Volumes ONTAP, such as IP addresses, netmasks, and routes. You need to make sure that outbound internet access is available, that enough private IP addresses are available, that the right connections are in place, and more.
Requirements for Cloud Volumes ONTAP
The following networking requirements must be met in Azure.
Outbound internet access
Cloud Volumes ONTAP systems require outbound internet access for accessing external endpoints for various functions. Cloud Volumes ONTAP can't operate properly if these endpoints are blocked in environments with strict security requirements.
The Console agent also contacts several endpoints for day-to-day operations. For information about endpoints, refer to View endpoints contacted from the Console agent and Prepare networking for using the Console.
Cloud Volumes ONTAP endpoints
Cloud Volumes ONTAP uses these endpoints to communicate with various services.
| Endpoints | Applicable for | Purpose | Deployment modes | Impact if unavailable |
https://netapp-cloud-account.auth0.com |
Authentication |
Used for authentication in the Console. |
Standard and restricted modes. |
User authentication fails and the following services remain unavailable:
https://vault.azure.net |
Key Vault |
Used to retrieve client secret keys from the Azure Key Vault when using customer-managed keys (CMK). |
Standard, restricted, and private modes. |
Cloud Volumes ONTAP services are unavailable. |
https://api.bluexp.netapp.com/tenancy |
Tenancy |
Used to retrieve the Cloud Volumes ONTAP resources from the Console to authorize resources and users. |
Cloud Volumes ONTAP resources and the users are not authorized. |
https://mysupport.netapp.com/aods/asupmessage |
AutoSupport |
Used to send AutoSupport telemetry data to NetApp support. |
AutoSupport information remains undelivered. |
https://management.azure.com |
Public regions |
Communication with Azure services. |
Cloud Volumes ONTAP cannot communicate with Azure service to perform specific operations for the Console in Azure. |
https://management.chinacloudapi.cn |
China Region |
https://management.microsoftazure.de |
Germany Region |
https://management.usgovcloudapi.net |
Government regions |
https://management.azure.microsoft.scloud |
Government DoD regions |
Network proxy configuration of NetApp Console agent
You can use the proxy servers configuration of the NetApp Console agent to enable outbound internet access from Cloud Volumes ONTAP. The Console supports two types of proxies:
Explicit proxy: The outbound traffic from Cloud Volumes ONTAP uses the HTTP address of the proxy server specified during the proxy configuration of the Console agent. The administrator might also have configured user credentials and root CA certificates for additional authentication. If a root CA certificate is available for the explicit proxy, make sure to obtain and upload the same certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
Transparent proxy: The network is configured to automatically route outbound traffic from Cloud Volumes ONTAP through the proxy for the Console agent. When setting up a transparent proxy, the administrator needs to provide only a root CA certificate for connectivity from Cloud Volumes ONTAP, not the HTTP address of the proxy server. Make sure that you obtain and upload the same root CA certificate to your Cloud Volumes ONTAP system using the ONTAP CLI: security certificate install command.
For information about configuring proxy servers, refer to the Configure the Console agent to use a proxy server.
IP addresses
The Console automatically allocates the required number of private IP addresses to Cloud Volumes ONTAP in Azure. You need to make sure that your networking has enough private IP addresses available.
The number of LIFs allocated for Cloud Volumes ONTAP depends on whether you deploy a single-node system or an HA pair. A LIF is an IP address associated with a physical port. An SVM management LIF is required for management tools like SnapCenter.
An iSCSI LIF provides client access over the iSCSI protocol and is used by the system for other important networking workflows. These LIFs are required and should not be deleted. |
IP addresses for a single-node system
The Console allocates 5 or 6 IP addresses to a single-node system:
Cluster management IP
Node management IP
Intercluster IP for SnapMirror
NFS/CIFS IP
iSCSI IP
The iSCSI IP provides client access over the iSCSI protocol. It is also used by the system for other important networking workflows. This LIF is required and should not be deleted. -
SVM management (optional - not configured by default)
IP addresses for HA pairs
The Console allocates IP addresses to 4 NICs (per node) during deployment.
Note that the Console creates an SVM management LIF on HA pairs, but not on single-node systems in Azure.
NIC0
Node management IP
Intercluster IP
iSCSI IP
NIC1
Cluster network IP
NIC2
Cluster Interconnect IP (HA IC)
NIC3
Pageblob NIC IP (disk access)
NIC3 is only applicable to HA deployments that use page blob storage. |
The above IP addresses do not migrate on failover events.
Additionally, 4 frontend IPs (FIPs) are configured to migrate on failover events. These frontend IPs live in the load balancer.
NodeA data IP (NFS/CIFS)
NodeB data IP (NFS/CIFS)
SVM management IP
Secure connections to Azure services
By default, the Console enables an Azure Private Link for connections between Cloud Volumes ONTAP and Azure page blob storage accounts.
In most cases, there's nothing that you need to do—the Console manages the Azure Private Link for you. But if you use Azure Private DNS, then you'll need to edit a configuration file. You should also be aware of a requirement for the location of the Console agent in Azure.
You can also disable the Private Link connection, if required by your business needs. If you disable the link, the Console configures Cloud Volumes ONTAP to use a service endpoint instead.
Networking for Azure VNet encryption
Cloud Volumes ONTAP supports Azure Virtual Network (VNet) encryption for encrypting VM-to-VM traffic inside a VNet or across peered VNets. This feature is configured at the Azure VNet layer and is independent of Cloud Volumes ONTAP topology (single node or HA).
You only need to ensure that Accelerated Networking is enabled on the VM's NICs and review Azure VNet encryption requirements and limitations before enabling the feature. You should not modify NetApp managed load balancer objects.
Connections to other ONTAP systems
To replicate data between a Cloud Volumes ONTAP system in Azure and ONTAP systems in other networks, you must have a VPN connection between the Azure VNet and the other network—for example, your corporate network.
For instructions, refer to the Microsoft Azure Documentation: Create a Site-to-Site connection in the Azure portal.
Port for the HA interconnect
A Cloud Volumes ONTAP HA pair includes an HA interconnect, which allows each node to continually check whether its partner is functioning and to mirror log data for the other’s nonvolatile memory. The HA interconnect uses TCP port 10006 for communication.
By default, communication between the HA interconnect LIFs is open and there are no security group rules for this port. But if you create a firewall between the HA interconnect LIFs, then you need to ensure that TCP traffic is open for port 10006 so that the HA pair can operate properly.
Only one HA pair in an Azure resource group
You must use a dedicated resource group for each Cloud Volumes ONTAP HA pair that you deploy in Azure. Only one HA pair is supported in a resource group.
The Console experiences connection issues if you try to deploy a second Cloud Volumes ONTAP HA pair in an Azure resource group.
Security group rules
The Console creates Azure security groups that include the inbound and outbound rules for Cloud Volumes ONTAP to operate successfully. View security group rules for the Console agent.
The Azure security groups for Cloud Volumes ONTAP require the appropriate ports to be open for internal communication between the nodes. Learn about ONTAP internal ports.
We do not recommend modifying the predefined security groups or using custom security groups. However, if you must, note that the deployment process requires the Cloud Volumes ONTAP system to have full access within its own subnet. After the deployment is complete, if you decide to modify the network security group, ensure to keep the cluster ports and HA network ports open, because the HA networking relies on unrestricted communication between the two nodes. Also, the IP addresses of the nodes are automatically defined during deployment. This ensures seamless communication within the Cloud Volumes ONTAP cluster (any-to-any communication between the nodes).
Inbound rules for single-node systems
When you add a Cloud Volumes ONTAP system and choose a predefined security group, you can choose to allow traffic within one of the following:
Selected VNet only: The source for inbound traffic is the subnet range of the VNet for the Cloud Volumes ONTAP system and the subnet range of the VNet where the Console agent resides. This is the recommended option.
All VNets: The source for inbound traffic is the 0.0.0.0/0 IP range.
Disabled: This option restricts the public network access to your storage account, and disables data tiering for Cloud Volumes ONTAP systems. This is a recommended option if your private IP addresses should not be exposed even within the same VNet due to security regulations and policies.
| Priority and name | Port and protocol | Source and destination | Description |
1000 |
22 |
Any to Any |
SSH access to the IP address of the cluster management LIF or a node management LIF |
1001 |
80 |
Any to Any |
HTTP access to the ONTAP System Manager web console using the IP address of the cluster management LIF |
1002 |
111 |
Any to Any |
Remote procedure call for NFS |
1003 |
111 |
Any to Any |
1004 |
139 |
Any to Any |
NetBIOS service session for CIFS |
1005 |
161-162 |
Any to Any |
Simple network management protocol |
1006 |
161-162 |
Any to Any |
1007 |
443 |
Any to Any |
Connectivity with the Console agent and HTTPS access to the ONTAP System Manager web console using the IP address of the cluster management LIF |
1008 |
445 |
Any to Any |
Microsoft SMB/CIFS over TCP with NetBIOS framing |
1009 |
635 |
Any to Any |
NFS mount |
1010 |
635 |
Any to Any |
NFS mount |
1011 |
749 |
Any to Any |
Kerberos |
1012 |
2049 |
Any to Any |
NFS server daemon |
1013 |
2049 |
Any to Any |
NFS server daemon |
1014 |
3260 |
Any to Any |
iSCSI access through the iSCSI data LIF |
1015 |
4045-4046 |
Any to Any |
NFS lock daemon and network status monitor |
1016 |
4045-4046 |
Any to Any |
1017 |
10000 |
Any to Any |
Backup using NDMP |
1018 |
11104-11105 |
Any to Any |
SnapMirror data transfer |
3000 |
Any port |
Any to Any |
Block all other TCP inbound traffic |
3001 |
Any port |
Any to Any |
Block all other UDP inbound traffic |
65000 |
Any port |
VirtualNetwork to VirtualNetwork |
Inbound traffic from within the VNet |
65001 |
Any port |
AzureLoadBalancer to Any |
Data traffic from the Azure Standard Load Balancer |
65500 |
Any port |
Any to Any |
Block all other inbound traffic |
Inbound rules for HA systems
HA systems have less inbound rules than single-node systems because inbound data traffic goes through the Azure Standard Load Balancer. Because of this, traffic from the Load Balancer should be open, as shown in the "AllowAzureLoadBalancerInBound" rule. |
100 |
443 |
Any to Any |
101 |
111 |
Any to Any |
102 |
2049 |
Any to Any |
NFS server daemon |
111 |
22 |
Any to Any |
121 |
53 |
Any to Any |
DNS and CIFS |
65000 |
Any port |
65001 |
Any port |
65500 |
Any port |
Any to Any |
Outbound rules
The predefined security group for Cloud Volumes ONTAP opens all outbound traffic. If that is acceptable, follow the basic outbound rules. If you need more rigid rules, use the advanced outbound rules.
Basic outbound rules
The predefined security group for Cloud Volumes ONTAP includes the following outbound rules.
| Port | Protocol | Purpose |
All |
All TCP |
All outbound traffic |
All |
All UDP |
Advanced outbound rules
If you need rigid rules for outbound traffic, you can use the following information to open only those ports that are required for outbound communication by Cloud Volumes ONTAP.
The source is the interface (IP address) on the Cloud Volumes ONTAP system. |
| Service | Port | Protocol | Source | Destination | Purpose |
Active Directory |
88 |
TCP |
Node management LIF |
Active Directory forest |
Kerberos V authentication |
137 |
UDP |
NetBIOS name service |
138 |
UDP |
NetBIOS datagram service |
139 |
TCP |
NetBIOS service session |
389 |
TCP & UDP |
LDAP |
445 |
TCP |
464 |
TCP |
Kerberos V change & set password (SET_CHANGE) |
464 |
UDP |
Kerberos key administration |
749 |
TCP |
Kerberos V change & set Password (RPCSEC_GSS) |
88 |
TCP |
Data LIF (NFS, CIFS, iSCSI) |
137 |
UDP |
Data LIF (NFS, CIFS) |
138 |
UDP |
139 |
TCP |
389 |
TCP & UDP |
LDAP |
445 |
TCP |
464 |
TCP |
464 |
UDP |
749 |
TCP |
Kerberos V change & set password (RPCSEC_GSS) |
AutoSupport |
HTTPS |
443 |
mysupport.netapp.com |
AutoSupport (HTTPS is the default) |
HTTP |
80 |
AutoSupport (only if the transport protocol is changed from HTTPS to HTTP) |
TCP |
3128 |
Console agent |
Sending AutoSupport messages through a proxy server on the Console agent, if an outbound internet connection isn't available |
Configuration backups |
HTTP |
80 |
http://<console-agent-IP-address>/occm/offboxconfig |
Send configuration backups to the Console agent. ONTAP documentation. |
DHCP |
68 |
UDP |
DHCP |
DHCP client for first-time setup |
DHCPS |
67 |
UDP |
DHCP |
DHCP server |
DNS |
53 |
UDP |
Node management LIF and data LIF (NFS, CIFS) |
DNS |
DNS |
NDMP |
18600–18699 |
TCP |
Destination servers |
NDMP copy |
SMTP |
25 |
TCP |
Mail server |
SMTP alerts, can be used for AutoSupport |
SNMP |
161 |
TCP |
Monitor server |
Monitoring by SNMP traps |
161 |
UDP |
Monitor server |
162 |
TCP |
Monitor server |
162 |
UDP |
Monitor server |
SnapMirror |
11104 |
TCP |
Intercluster LIF |
ONTAP intercluster LIFs |
Management of intercluster communication sessions for SnapMirror |
11105 |
TCP |
Intercluster LIF |
Syslog |
514 |
UDP |
Syslog server |
Syslog forward messages |
Requirements for the Console agent
If you haven't created a Console agent yet, you should review networking requirements for the Console agent as well.
