Enable NetApp ransomware protection solutions for Cloud Volumes ONTAP
Ransomware attacks can cost a business time, resources, and reputation. The NetApp Console enables you to implement two NetApp solutions for ransomware: Protection from common ransomware file extensions and Autonomous Ransomware Protection (ARP). These solutions provide effective tools for visibility, detection, and remediation.
Available on the Console, the Ransomware Protection setting allows you to utilize the ONTAP FPolicy functionality to guard against common ransomware file extension types.
On the Systems page, double-click the name of the Cloud Volumes ONTAP system you configure to use ransomware protection.
On the Overview tab, click the Features panel and then click the pencil icon next to Ransomware Protection.
Implement the NetApp solution for ransomware:
Click Activate Snapshot Policy, if you have volumes that do not have a Snapshot policy enabled.
NetApp Snapshot technology provides the industry’s best solution for ransomware remediation. The key to a successful recovery is restoring from uninfected backups. Snapshot copies are read-only, which prevents ransomware corruption. They can also provide the granularity to create images of a single file copy or a complete disaster recovery solution.
Click Activate FPolicy to enable ONTAP's FPolicy solution, which can block file operations based on a file's extension.
This preventative solution improves protection from ransomware attacks by blocking common ransomware file types.
The default FPolicy scope blocks files that have the following extensions:
micro, encrypted, locked, crypto, crypt, crinf, r5a, XRNT, XTBL, R16M01D05, pzdc, good, LOL!, OMG!, RDM, RRK, encryptedRS, crjoker, EnCiPhErEd, LeChiffre
This scope is created when you activate FPolicy on Cloud Volumes ONTAP. The list is based on common ransomware file types. You can customize the blocked file extensions by using the vserver fpolicy policy scope commands from the Cloud Volumes ONTAP CLI.
Cloud Volumes ONTAP supports the Autonomous Ransomware Protection (ARP) feature, which performs analyses on workloads to proactively detect and warn about abnormal activity that might indicate a ransomware attack.
Separate from the file extension protections provided through the ransomware protection setting, the ARP feature uses workload analysis to alert the user on potential attacks based on detected “abnormal activity”. Both the ransomware protection setting and the ARP feature can be used in conjunction for comprehensive ransomware protection.
The ARP feature is available for use with bring your own license (BYOL) and marketplace subscriptions for your licenses at no additional cost.
ARP-enabled volumes have a designated state of "Learning mode" or "Active".
Configuration of ARP for volumes is performed through ONTAP System Manager and ONTAP CLI.
For more information on how to enable ARP with ONTAP System Manager and the ONTAP CLI, refer to the ONTAP documentation: Enable Autonomous Ransomware Protection.
