Cloud Volumes ONTAP
Deploy Cloud Volumes ONTAP from the Azure Marketplace
Contributors netapp-manini netapp-ahibbard
You can use Azure Marketplace direct deployment to quickly and easily deploy Cloud Volumes ONTAP. From the Azure Marketplace, you can quickly deploy Cloud Volumes ONTAP in a few clicks and explore its core features and capabilities in your environment.
About this task
The Cloud Volumes ONTAP system deployed by using Azure Marketplace direct deployment has these properties. Note that the features of a standalone instance deployed through the Azure Marketplace change when it is discovered in the NetApp Console.
  • The latest Cloud Volumes ONTAP version (9.16.1 or later).
  • A free license for Cloud Volumes ONTAP is provided for up to 500 GiB of provisioned capacity, with no NetApp support and no expiry date. Capacity beyond 500 GiB requires a valid licensing entitlement and may incur charges. To access the full Cloud Volumes ONTAP experience and advanced management capabilities, connect your Cloud Volumes ONTAP system to the Console. Discovery and management through the Console require a valid Azure Marketplace subscription associated with your Console account.
  • Two nodes configured in a high availability (HA) mode in a single availability zone (AZ), provisioned with default serial numbers. The storage virtual machines (storage VMs) are deployed in a flexible orchestration mode.
  • An aggregate for the instance created by default.
  • A Premium SSD v2 Managed Disk of 500 GiB provisioned capacity, and a root and a data disk.
  • One data storage VM deployed, with NFS, CIFS, iSCSI, and NVMe/TCP data-services. You cannot add any additional data storage VMs.
  • Licenses installed for NFS, CIFS (SMB), iSCSI, Autonomous Ransomware Protection (ARP), SnapLock, and SnapMirror.
  • ONTAP temperature-sensitive storage efficiency (TSSE), volume encryption, and external key-management enabled by default.
  • These features are not supported:
    • FabricPool tiering
    • Changing the storage VM type
    • Fast write mode
Before you begin
  • If you plan to discover and manage the deployed system in the Console, ensure that the Console account is associated with a valid Azure Marketplace subscription. Discovery of the system into the Console requires a valid subscription.
  • Ensure you meet the networking requirements for an HA deployment in a single AZ in Azure. Refer to Set up Azure networking for Cloud Volumes ONTAP.
  • You need to be assigned one of these Azure roles to deploy Cloud Volumes ONTAP:
    • The contributor role with the default permissions. For more information, refer to the Microsoft Azure documentation: Azure built-in roles.
    • A custom RBAC role with the following permissions. For more information, refer to the Azure documentation: Azure custom roles.
      "permissions": [
      "actions": [
      "Microsoft.AAD/register/action",
      "Microsoft.Resources/subscriptions/resourceGroups/write",
      "Microsoft.Network/loadBalancers/write",
      "Microsoft.ClassicCompute/virtualMachines/write",
      "Microsoft.Compute/capacityReservationGroups/deploy/action",
      "Microsoft.ClassicCompute/virtualMachines/networkInterfaces/associatedNetworkSecurityGroups/write",
      "Microsoft.Network/networkInterfaces/write",
      "Microsoft.Compute/virtualMachines/write",
      "Microsoft.Compute/virtualMachines/extensions/write",
      "Microsoft.Resources/deployments/validate/action",
      "Microsoft.Resources/subscriptions/resourceGroups/read",
      "Microsoft.Network/virtualNetworks/write",
      "Microsoft.Network/virtualNetworks/read",
      "Microsoft.Network/networkSecurityGroups/write",
      "Microsoft.Network/networkSecurityGroups/read",
      "Microsoft.Compute/disks/write",
      "Microsoft.Compute/virtualMachineScaleSets/write",
      "Microsoft.Resources/deployments/write",
      "Microsoft.Network/virtualNetworks/subnets/read",
      "Microsoft.Network/virtualNetworks/subnets/write"
      "notActions": [],
      "dataActions": [],
      "notDataActions": []
      Note If you have registered the resource provider "Microsoft.storage" to your subscription, then you don't need the Microsoft.AAD/register/action permission. For more information, refer to the Azure documentation: Azure permissions for Storage.
Steps
  1. From the Azure Marketplace site, search for NetApp products.
  2. Select NetApp Cloud Volumes ONTAP direct.
  3. Select Create to launch the deployment wizard.
  4. Select a plan. The Plan list typically displays the latest releases of Cloud Volumes ONTAP.
  5. In the Basics tab, provide these details:
    • Subscription: Select a subscription. The deployment will be linked to the subscription number.
    • Resource group: Use an existing resource group or create a new one. Resource groups help in allocating all resources, such as disks and storage VMs, within a single group for a Cloud Volumes ONTAP system.
    • Region: Select a region that supports Azure HA deployment in a single AZ. You see only the available regions on the list.
    • Size: Select an storage VM size for the supported Premium SSD v2 Managed Disk.
    • Zone: Select a zone for the region you selected.
    • Admin Password: Set a password. You use this admin password to log in to the system after the deployment.
    • Confirm Password: Re-enter the same password for confirmation.
      • In the Network tab, add a virtual network and a subnet, or select them from the lists.
        Note To comply with Microsoft Azure restrictions, you should create a new subnet when setting up a new virtual network. Likewise, if you choose an existing network, you should select an existing subnet.
      • To select a predefined network security group, select Yes. Select No to assign a predefined Azure network security group with the necessary traffic rules. For more information, refer to Security group rules for Azure.
      • In the Advanced tab confirm whether the two Azure features necessary for this deployment have been set. Refer to Enable an Azure feature for Cloud Volumes ONTAP single AZ deployments and Enable high-availability mode for Cloud Volumes ONTAP in Azure.
      • You can define name and value pairs for the resources or resource groups in the Tags tab.
      • In the Review + create tab, review the details and start the deployment.
After you finish
Select the notification icon to view the progress of your deployment. After Cloud Volumes ONTAP is deployed, you can view the storage VM listed for operations.
Once accessible, use ONTAP System Manager or the ONTAP CLI to log in to the storage VM with the admin credentials that you set. Thereafter, you can create volumes, LUNs, or shares and start utilizing the storage capabilities of Cloud Volumes ONTAP.
Troubleshoot deployment issues
Cloud Volumes ONTAP systems deployed directly through the Azure Marketplace do not include support from NetApp. If any issues arise during deployment, you can independently troubleshoot and resolve them.
Steps
  1. On the Azure Marketplace site, go to Boot diagnostics > Serial log.
  2. Download and investigate the serial logs.
  3. Consult the product documentation and knowledge base (KB) articles for troubleshooting.
Discover the deployed systems in Console
You can discover the Cloud Volumes ONTAP systems that you deployed using Azure Marketplace direct deployment and manage them on the Systems page in the Console. The Console agent discovers the systems, adds them and applies the necessary licenses, and unlocks the full capabilities of the Console for these systems. The original HA configuration in a single AZ with PSSD v2 Managed Disks is retained, and the system is registered to the same Azure subscription and resource group as the original deployment.
About this task
On discovering the Cloud Volumes ONTAP systems deployed using Azure Marketplace direct deployment, the Console agent performs these tasks:
  • Replaces the free licenses of the discovered systems as regular capacity-based Freemium licenses.
  • Retains the existing capabilities of the deployed systems, and adds the additional capabilities of the Console, such as data protection, data management, and security features.
  • Replaces the installed licenses on the nodes with new ONTAP licenses for NFS, CIFS (SMB), iSCSI, ARP, SnapLock, and SnapMirror.
  • Converts the generic node serial numbers to unique serial numbers.
  • Assigns new system tags on the resources as required.
  • Converts the dynamic IP addresses of the instance to static IP addresses.
  • Enables the functionalities of FabricPool tiering, AutoSupport, and write-once-read-many (WORM) storage on the deployed systems. You can activate these features from the Console when you need them.
  • Registers the instances to the NSS accounts used to discover them.
  • Enables capacity management features in automatic and manual modes for the discovered systems.
Before you begin
Ensure that the deployment is complete on the Azure Marketplace. The Console agent can discover the systems only when the deployment is complete and are available for discovery.
Steps
In the Console, you follow the standard procedure for discovering existing systems. Refer to Add an existing Cloud Volumes ONTAP system to the Console.
Caution During discovery, you might see failure messages, but you can ignore them until the discovery process is complete. Do not modify the system-generated Cloud Volumes ONTAP configurations in the Azure Marketplace portal during discovery, especially the system tags. Any changes made to these configurations may lead to unexpected system behavior.
After you finish
After the discovery is complete, you can view the systems listed on the Systems page in the Console. You can perform various management tasks, such as expanding the aggregate, adding volumes, provisioning additional storage VMs, and changing the instance types.
Related links
Refer to the ONTAP documentation for more information about creating storage:
