Connect to a LUN on Cloud Volumes ONTAP from your host system
When you create an iSCSI volume, BlueXP automatically creates a LUN for you. We’ve made it simple by creating just one LUN per volume, so there's no management involved. After you create the volume, use the IQN to connect to the LUN from your hosts.
Note the following:
BlueXP's automatic capacity management doesn't apply to LUNs. When BlueXP creates a LUN, it disables the autogrow feature.
You can create additional LUNs from ONTAP System Manager or the ONTAP CLI.
From the left navigation menu, select Storage > Canvas.
On the Canvas page, double-click the Cloud Volumes ONTAP working environment on which you want to manage volumes.
In the working environment, click the Volumes tab.
On the Volumes tab, navigate to the desired volume title and then click Manage volume to access the Manage Volumes right-side panel.
Click Target iQN.
Click Copy to copy the iQN name.
Set up an iSCSI connection from the host to the LUN.
