Integrate your Active Directory with BlueXP classification
You can integrate a global Active Directory with BlueXP classification to enhance the results that BlueXP classification reports about file owners and which users and groups have access to your files.
When you set up certain data sources (listed below), you need to enter Active Directory credentials in order for BlueXP classification to scan CIFS volumes. This integration provides BlueXP classification with file owner and permissions details for the data that resides in those data sources. The Active Directory entered for those data sources might differ from the global Active Directory credentials you enter here. BlueXP classification will look in all integrated Active Directories for user and permission details.
This integration provides additional information in the following locations in BlueXP classification:
You can use the "File Owner" filter and see results in the file's metadata in the Investigation pane. Instead of the file owner containing the SID (Security IDentifier), it is populated with the actual user name.
You can see full file permissions for each file and directory when you click the "View all Permissions" button.
In the Governance dashboard, the Open Permissions panel will show a greater level of detail about your data.
Local user SIDs, and SIDs from unknown domains, are not translated to the actual user name. |
Supported data sources
An Active Directory integration with BlueXP classification can identify data from within the following data sources:
On-premises ONTAP systems
Cloud Volumes ONTAP
Azure NetApp Files
FSx for ONTAP
OneDrive accounts and SharePoint accounts (for legacy versions 1.30 and earlier)
There is no support for identifying user and permission information from Database schemas, Google Drive accounts, Amazon S3 accounts, or Object Storage that uses the Simple Storage Service (S3) protocol.
Connect to your Active Directory server
After you've deployed BlueXP classification and have activated scanning on your data sources, you can integrate BlueXP classification with your Active Directory. Active Directory can be accessed using a DNS Server IP address or an LDAP Server IP address.
The Active Directory credentials can be read-only, but providing admin credentials ensures that BlueXP classification can read any data that requires elevated permissions. The credentials are stored on the BlueXP classification instance.
For CIFS volumes/file shares, if you want to make sure your files "last accessed times" are unchanged by BlueXP classification classification scans, we recommend that the user has Write Attributes permission. If possible, we recommend making the Active Directory configured user part of a parent group in the organization which has permissions to all files.
You must have an Active Directory already set up for the users in your company.
You must have the information for the Active Directory:
DNS Server IP address, or multiple IP addresses
or
LDAP Server IP address, or multiple IP addresses
User Name and Password to access the server
Domain Name (Active Directory Name)
Whether you are using secure LDAP (LDAPS) or not
LDAP Server Port (typically 389 for LDAP, and 636 for secure LDAP)
The following ports must be open for outbound communication by the BlueXP classification instance:
Protocol Port Destination Purpose TCP & UDP
389
Active Directory
LDAP
TCP
636
Active Directory
LDAP over SSL
TCP
3268
Active Directory
Global Catalog
TCP
3269
Active Directory
Global Catalog over SSL
From the BlueXP classification Configuration page, click Add Active Directory.
In the Connect to Active Directory dialog, enter the Active Directory details and click Connect.
You can add multiple IP addresses, if required, by clicking Add IP.
BlueXP classification integrates to the Active Directory, and a new section is added to the Configuration page.
Manage your Active Directory integration
If you need to modify any values in your Active Directory integration, click the Edit button and make the changes.
You can also delete the integration if you no longer need it by clicking the button and then Remove Active Directory.
