BlueXP classification
Install BlueXP classification on multiple hosts for large configurations with no internet access
Contributors amgrissino netapp-ahibbard
Complete a few steps to install BlueXP classification on multiple hosts in an on-premises site that doesn't have internet access - also known as private mode. This type of installation is perfect for your secure sites.
For very large configurations where you'll be scanning petabytes of data in sites without internet access, you can include multiple hosts to provide additional processing power. When using multiple host systems, the primary system is called the Manager node and the additional systems that provide extra processing power are called Scanner nodes.
Follow these steps when installing BlueXP classification software on multiple on-premises hosts in an offline environment.
Note The following information is relevant only for BlueXP classification legacy versions 1.30 and earlier.
Before you begin
  • Verify that all your Linux systems for the Manager and Scanner nodes meet the host requirements.
  • Verify that you have installed the two prerequisite software packages (Docker Engine or Podman, and Python 3).
  • Make sure you have root privileges on the Linux systems.
  • Verify that your offline environment meets the required permissions and connectivity.
  • You must have the IP addresses of the scanner node hosts that you plan to use.
  • The following ports and protocols must be enabled on all hosts:
    Port Protocols Description
    2377
    TCP
    Cluster management communications
    7946
    TCP, UDP
    Inter-node communication
    4789
    UDP
    Overlay network traffic
    50
    ESP
    Encrypted IPsec overlay network (ESP) traffic
    111
    TCP, UDP
    NFS Server for sharing files between the hosts (needed from each scanner node to manager node)
    2049
    TCP, UDP
Steps
  1. Follow steps 1 through 8 from the Single-host installation on the manager node.
  2. As shown in step 9, when prompted by the installer, you can enter the required values in a series of prompts, or you can provide the required parameters as command line arguments to the installer.
    In addition to the variables available for a single-host installation, a new option -n <node_ip> is used to specify the IP addresses of the scanner nodes. Multiple node IPs are separated by a comma.
    For example, this command adds 3 scanner nodes:
    sudo ./install.sh -a <account_id> -c <client_id> -t <user_token> --host <ds_host> --manager-host <cm_host> -n <node_ip1>,<node_ip2>,<node_ip3> --no-proxy --darksite
  3. Before the manager node installation completes, a dialog displays the installation command needed for the scanner nodes. Copy the command (for example: sudo ./node_install.sh -m 10.11.12.13 -t ABCDEF-1-3u69m1-1s35212) and save it in a text file.
  4. On each scanner node host:
    1. Copy the Data Sense installer file (cc_onprem_installer.tar.gz) to the host machine.
    2. Unzip the installer file.
    3. Paste and run the command that you copied in step 3.
      When the installation finishes on all scanner nodes and they have been joined to the manager node, the manager node installation finishes as well.
Result
The BlueXP classification installer finishes installing packages, and registers the installation. Installation can take 15 to 25 minutes.
What's Next
From the Configuration page you can select the local on-prem ONTAP clusters and local databases that you want to scan.
