Scanning database schemas
Complete a few steps to start scanning your database schemas with BlueXP classification.
Quick start
Get started quickly by following these steps, or scroll down to the remaining sections for full details.
Ensure that your database is supported and that you have the information necessary to connect to the database.
Deploy BlueXP classification if there isn’t already an instance deployed.
Add the database server that you want to access.
Select the schemas that you want to scan.
Reviewing prerequisites
Review the following prerequisites to make sure that you have a supported configuration before you enable BlueXP classification.
Supported databases
BlueXP classification can scan schemas from the following databases:
Amazon Relational Database Service (Amazon RDS)
MongoDB
MySQL
Oracle
PostgreSQL
SAP HANA
SQL Server (MSSQL)
The statistics gathering feature must be enabled in the database. |
Database requirements
Any database with connectivity to the BlueXP classification instance can be scanned, regardless of where it is hosted. You just need the following information to connect to the database:
IP Address or host name
Port
Service name (only for accessing Oracle databases)
Credentials that allow read access to the schemas
When choosing a user name and password, it’s important to choose one that has full read permissions to all the schemas and tables you want to scan. We recommend that you create a dedicated user for the BlueXP classification system with all the required permissions.
Note: For MongoDB, a read-only Admin role is required.
Deploying the BlueXP classification instance
If you are scanning database schemas that are accessible over the internet, you can deploy BlueXP classification in the cloud or deploy BlueXP classification in an on-premises location that has internet access.
If you are scanning database schemas that have been installed in a dark site that has no internet access, you need to deploy BlueXP classification in the same on-premises location that has no internet access. This also requires that the BlueXP Connector is deployed in that same on-premises location.
Upgrades to BlueXP classification software is automated as long as the instance has internet connectivity.
Adding the database server
Add the database server where the schemas reside.
From the Working Environments Configuration page, click Add Data Source > Add Database Server.
Enter the required information to identify the database server.
Select the database type.
Enter the port and the host name or IP address to connect to the database.
For Oracle databases, enter the Service name.
Enter the credentials so that BlueXP classification can access the server.
Click Add DB Server.
The database is added to the list of working environments.
Enabling and disabling compliance scans on database schemas
You can stop or start full scanning of your schemas at any time.
There is no option to select mapping-only scans for database schemas. |
From the Configuration page, click the Configuration button for the database you want to configure.
Select the schemas that you want to scan by moving the slider to the right.
BlueXP classification starts scanning the database schemas that you enabled. If there are any errors, they’ll appear in the Status column, alongside the required action to fix the error.
Note that BlueXP classification scans your databases once per day - databases are not continuously scanned like other data sources.
