Removing data sources from BlueXP classification
If you need to, you can stop BlueXP classification from scanning one or more working environments, databases, file share groups, OneDrive accounts, Google Drive accounts, or SharePoint accounts.
Charging for scanning the data is stopped when the data source is removed.
Deactivating compliance scans for a working environment
When you deactivate scans, BlueXP classification no longer scans the data on the working environment and it removes the indexed compliance insights from the BlueXP classification instance (the data from the working environment itself isn't deleted).
From the Configuration page, click the
button in the row for the working environment, and then click Deactivate Data Sense.
You can also disable compliance scans for a working environment from the Services panel when you select the working environment. |
Removing a database from BlueXP classification
If you no longer want to scan a certain database, you can delete it from the BlueXP classification interface and stop all scans.
button in the row for the database, and then click Remove DB Server.
Removing a OneDrive, SharePoint, or Google Drive account from BlueXP classification
If you no longer want to scan user files from a certain OneDrive account, from a specific SharePoint account, or from a Google Drive account, you can delete the account from the BlueXP classification interface and stop all scans.
button in the row for the OneDrive, SharePoint, or Google Drive account, and then click Remove OneDrive Account, Remove SharePoint Account, or Remove Google Drive account.
Click Delete Account from the confirmation dialog.
Removing a group of file shares from BlueXP classification
If you no longer want to scan user files from a file shares group, you can delete the File Shares Group from the BlueXP classification interface and stop all scans.
button in the row for the File Shares Group, and then click Remove File Shares Group.
Click Delete Group of Shares from the confirmation dialog.
