Ripresa di una relazione SnapVault con Data ONTAP in 7-Mode
Se si esegue il ripristino utilizzando un backup Snapshot diverso da quello più recente, è necessario ripristinare la relazione SnapVault in modo che Snap Creator possa continuare a eseguire i backup.
Riprendere la relazione SnapVault con Data ONTAP in 7-Mode immettendo il seguente comando. SnapVault start -r -S source_controller:source_volumebackup_controller:backup_volume
Eseguire questo passaggio per tutti i volumi appartenenti al database SAP HANA.
hana2b> snapvault start -r -S hana1a:/vol/data_00001/mnt00001 hana2b:/vol/backup_data_00001/mnt00001 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:08:21 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00001/mnt00001 to hana1a:/vol/data_00001/mnt00001 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
hana2b> snapvault start -r -S hana1b:/vol/data_00002/mnt00002 hana2b:/vol/backup_data_00002/mnt00002 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:09:49 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00002/mnt00002 to hana1b:/vol/data_00002/mnt00002 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
hana2b> snapvault start -r -S hana1a:/vol/data_00003/mnt00003 hana2b:/vol/backup_data_00003/mnt00003 The resync base snapshot will be: Backup-ANA-SV_daily_20140406200000 Resync may alter the data in this qtree. Are you sure you want to resync the qtree? y Mon Apr 7 14:10:25 CEST [hana2b:replication.dst.resync.success:notice]: SnapVault resync of /vol/backup_data_00003/mnt00003 to hana1a:/vol/data_00003/mnt00003 was successful. Transfer started. Monitor progress with 'snapvault status' or the snapmirror log.
Al termine del trasferimento dei dati, è possibile pianificare nuovamente i backup utilizzando Snap Creator.
